Question about Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black
My razor blade heads no longer rotate but when removed the mechanism underneath is spinning normally - the razor is clean and fully charged.
  • Norelco Master
  • 1,600 Answers
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on May 08, 2010
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
How do i clean my with my philips hq2000. instructions are in a different langue
  • 1 Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
  • 2 Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
  • 3 Plug the power cord of the cleaning base into and electrical outlet.
  • 4 Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
  • 5 Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
  • 6 Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
  • 7 Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
  • If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
  • Jul 22, 2014 | Philips Norelco Hq200 Jet Clean Solution 2...
    I have braun shaver 190s1 fully charged but the blades are not rotating for me to shave
    One or more of the shaving heads is stuck on the blade foil. The latter is very delicate and wears. If there is a break in the foil often a metal shard intrudes into the path of the moving blades and it gets stuck. Remove the foil and turn on shaver - if it runs it is the foil that has to be replaced.
    Nov 22, 2013 | Braun Health & Beauty
    Norelco Spectra 8865 XL Razor running slowly
    there is whiskers under the heads,you need a small brush to clean them or your owners manual tells you how to remove heads which you can probable figure out yourself.
    May 27, 2012 | Norelco Spectra 8865 XL Electric Shaver
    I have a norelco arcitec shaver and the heads no longer turn. I haven't had it that long so of course very disappointed with the razor. I would like to take it apart to clean it, thinking there may...
    You are problable correct in thinking that the blades are clogged up. Unfortunately, you are also correct about the terrible design. The blades on Arcitec models can not be removed from the head assembly for cleaning
    complaints can be made to Noreclo at 1-800-243-3050
    Replacement head assembly can be purchase from shaveroutlet.com. See link below
    http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
    May 10, 2011 | Health & Beauty
    Model 8060X locked up and will not spin. When I remove the shaver head, the razor spins like normal, but when I replace the head it will not spin. What could be the root of the problem and possible...
    It would appear that the head is damaged and blade(s) is jammed into the comb, preventing the blades from turning. You will need to replace the heads. You will find replacements at shaveroutlet.com. See link below
    http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hs85-replacement-heads-p-253.html
    Feb 13, 2011 | Norelco Health & Beauty
    I have a Norelco model 7315 razor that I purchased in October 2009. In the last five weeks, in spite of being cleaned regularly, it developed a very unpleasant must odor that seems to emanate from the body...
    It is very unlikely that the smell is coming from the body of the shaver. Have you completely removed the heads and thoroughly cleaned them individually with alcohol or shaver cleaner? If you are simply rinsing the blades under the faucet and have not removed them and thoroughly cleaned them, this is almost certainly the problem. The smell is decomposing hair and oils from your skin.
    You may want to consider using a shaver cleaning product like the ones linked below from shaveroutlet.com
    http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
    http://shaveroutlet.com/shaver-accessories/eltron/eltron-parks-shaver-cleaner-p-737.html
    Jun 29, 2010 | Norelco Rechargeable Cordless Men's Razor...
    Shaver suddenly stopped working
    I had the same problem with mine right after the two year warranty expired.
    BUT I FIXED IT!!!
    The problem seems to be bad engineering. Apparently the cleaning solution works its way into the circuit board of the shaver.
    I took the razor apart (you need very small phillips screwdrivers), there are six screws. First remove the foils, then the blades (just pull them up). Two screws are where the head rotates. after removing the head, there are two more screws underneath the head. There are two more screws on the bottom under plastic caps beside the charging terminal. You can now gently slide the razor's hardware out of the case by pulling up on the head mounting arms while holding the case as you normally would shaving. (This sounds confusing but should be obvious as you do it.)
    Looking at the circuit board i noticed some white residue on the board. I gently cleaned the board with small amount of alcohol and q-tips, being careful not to catch any cotton on the components of the board. At this point you can at least confirm that the motor is not burnt out and the batteries are charged by placing a flathead screwdriver between the positive terminal of the battery and the motor. It should come on if the motor and batteries are okay.
    Next you hit the reset button at the bottom-front, then see if it comes on using the on/off button. You can do this step with the razor disassembled or assembled.
    Hopefully this works for you. Now if only i could figure out a way to clean and refill the cartridges instead of paying $5 for 5 cents worth of cleaning fluid.
    Feb 03, 2009 | Braun Flex XP II 5790 Electric Shaver
    Philips cool skin shaver fault
    The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
    Sep 10, 2007 | Philips Philishave Cool Skin HQ6760/HQ...
    Hoover windtunnel u6634-900
    I have the same problem. I believe, after some inspection, that the mechanism which allows for the circular spin of the brush has failed. Though I'm no mechanic, I believe my girlfriend's long (and beautiful) hair became entangled underneath the gray "end-cap" causing breakage of the rotating mechanism (which I believe is normally housed within the brush under the rectangular "end-cap"...the other "end-cap" piece is circular). Now the brush will spin about 6 rotations but with each spin the gray "end-cap" will extend on its screw rather than spinning freely. I believe my only option is to order another brush. We'll see if it solves the problem.
    Jun 23, 2007 | Hoover U6634-900 WindTunnel Bagless...
    Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black Logo
    531 people viewed this question
    Top Norelco Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Kazim ERGUNEY
    Kazim ERGUNEY
    Andrew Taylor
    Andrew Taylor
    Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
