There is no spect printed on the cap - Computers & Internet
    Master:
  • 497 Answers
Hello, I will try to help. But first, I need a little more information about the device you are talking about. (i.e: Manufacturer Name & Model) and describe your issue with more detail if you could. Thank You. Lucky4lynn2
Posted on May 06, 2010
I have removed an upstairs lavatory. The pipe rises internally and has a vent. Can I seal off the pipe under the floor nd do i have to replace the vent?
If is no longer a rest room and don't require any drainage then you can just cap off. The vent is only needed as per building spects for a bathroom.
Jan 05, 2015 | GF Piping Systems 447-030L - Cap, 3 In,...
What are engine torque specs
witch engine go to autozone or similar parts house and ask for them to print the torque spects for that engine
Aug 22, 2014 | Cars & Trucks
LG tv stuck on standby. often won't come on for hours
In spect the power supply module for any sign of bad caps with bulging/leaking tops.
Similar to the 37' version:
http://s807.photobucket.com/albums/yy352/budm/LG/LG%2037LC2D/
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=42LC2D&kategoria=tv&kat2=schematics
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
I need torque spects for a 98 4.0 jeep on rods and mains.
  1. Tighten all main bearing bolts to 108 Nm (80 ft. lbs.) torque.
  2. Install the main bearing cap brace. Tighten nuts to 47 Nm (35 ft. lbs.) .
Connecting Rod Nuts 33 ft.lb
Dec 06, 2010 | 1998 Jeep Grand Cherokee
I need to know he torque spects for the oil filter container the bolts on to the moter on a 94 BMW 318i...there are 6 bolts...I also need to know the torque spects on the alternator mounting bracket...
OIL PAN OR TRANSMISSION PAN BOLTS TORQUE ABOUT 7 FT LBS. CAN GET SPECS ON BOLTS SIZES. IF BOLTS SIZES IS 13M I4M 15 M TORQUE BOLTS ABOUT 55 TO 80 FT LBS
Nov 11, 2010 | 1994 BMW 3 Series
Need spects for carburetor main jet on mikuni ucal and spects for pilot air jet 1 and pilot jet 2
http://www.cmsnl.com/yamaha-yz125r-2003_model11245/partslist/A-12.html
Site above has all the parts and specs for your bike. Jet ranges are large for a YZ as many mod's are available and riding conditions contribute largely to a peaky 2 banger. Start with #40 pilot, and #420 main. Trial and error from there. Cheers.
Apr 26, 2010 | 2003 Yamaha YZ 125
Rear main seal is leaking bad so I need to pull the motor (k1500 305)should I pull motor and trans together or just the motor. Any tips and shuold I replace anything else since I have the engine out.
you dont have too pull the motor!!
remove the radiator shroud, remove the distributor cap and rotor, take pipes lose from exsaulst manifold, take out motor mount bolts pick the engine up with a hoist, you now have enough room too drop the oil pan!!remove rear main bearing cap, take lower half of seal out of cap, too remove the up half of seal ,i use a small screwdriver too slide it around the crank ,
grease up the new one and it will slide right in!!
in spect the rod and main bearings while you have it apart and think about replacing them they dont cost much about 4.00 each and if you go that far replace the oil pump its not much either under 30.00!!
Mar 05, 2010 | 1988 Chevrolet K1500
Im looking for torque specs for factory jugs and head for banshee can someone please help,lost my book and to late to get one, thank you
Look up the spects on your bolt size, ie, 8 mm or 10 mm.  You can find generic spects on the net. Per bolt size not socket size, but the bolt. You can measure the bolt with a end wrench though. Put the end wrinch on the bolt at the threads till one will fit, thats the bolt size. Some spects call for dry or wet numbers. Wet just means lightly oiled.
Aug 04, 2009 | Yamaha RD 350 Motorcycles
What is the convergance??
tv model is pt4298hd repair shop said that he replace both convergance chips check all res/caps all reading in spects.
Dec 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
