Question about Xerox WorkCentre Pro 635 Laser Printer
Xerox 657 drum reset instructions - Xerox WorkCentre Pro 635 Laser Printer
Need to replace 1/16 A pick-tale(brown color with strips on it) fuse on blank lamp assembly in drum unit
Posted on Sep 01, 2010
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Reseting xerox drum chip xerox 5834/vivace 340
you should change drum chip then fix your problem
Apr 01, 2009 | Xerox Office Equipment & Supplies
Nothing prints on page
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Nov 25, 2008 | Xerox DocuColor 3535 Copier
Xerox Workcenter Pro 657 Memory Error
With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
Oct 16, 2008 | Xerox WorkCentre Pro 635 Laser Printer
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 635 Laser Printer Logo
325 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
