Question about Rockford Fosgate Car Audio & Video
How do i know my p3001 amp is on? - Rockford Fosgate Car Audio & Video
I need parts for an amp
callem up im sure someone in tech dept. call help ya jus cus its not on a screen dosent mean rockford doesnt have it....i mean they made the amp n all .....u know
May 14, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 problem
if amp is mounted to back of the box try and move to in front of box near subs or port. the air movement of the sub will help keep the amp cooled. or you can orer some 12v cooling fans and take back plate of the amp and cool it that way. or you can buy higher quality audio, your choice
Feb 20, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford P3001 amp not working
peel the cover completely off the amp and give it some power- if the amp is blown there will be a tiny light lit up on the circiut board that quite simply says "SHORT"-If its blown then theres nothing you can do unless you are a badass of course- but if the amp is dear to you and you want to spend a little money on it to get it up and running again- go to rockfords website and get into the forums and ask the question-where do i get my fosgate fixed and it will pull up some mumbo jumbo but it tells you about a place called LANDIS TECHNICAL that bought up all the parts to their amps and is in the business of restoring the amplifiers to their factory specs and even sends you a new power certificate to go with your new and improved amp.hope that helps you-
May 26, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
My amp wont give me any power
all the p series amps were discontinued for similar problems, they have a newer model out now. they have very weak boards internally and failed faster when mounted to the sub enclosure or very close to it from subsonic vibration. i would guess the amp is toasted.
Dec 17, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
RF P3001 power problems
check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
Nov 15, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
See if you can read any markings on this part. If you can't, maybe a photo might provide a clue.
Sep 28, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Car Audio & Video Logo
21 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
