Question about La Pavoni Caffe Mattina ESP-20 Coffee Maker
The button on the pavoni caffe matina stopped working - how to fix it - the screws on the bottom are triangular not for stndard screw driver - so i don't knwo how to open
2 Suggested Answers
z34aga
  • 137 Answers
SOURCE: adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Posted on Mar 30, 2009
I need 120 v 1500 WATT TRIANGULAR FLANGED 2 PRONG HEATING ELEMENT FOR A PUBV1
You can check with Espressopartsnw.com or crossroads espresso(coffeestuff.com) they are the pavoni distributors.
Apr 06, 2011 | La Pavoni Pub V1 Espresso Machine
Tip
How to remove the door panels on Mercedes Benz?
1) First of all you need to remove the triangular panel near the rear view mirror. The mirror is fitted with clip under it. You will first need to unlock the clip. For this you will require a standard screwdriver.
2) Then there is a screws holding the black metal cover .this screw is fitted on door jamb. Remove this screw.
3) Then its time to remove the air bag badge .the air bag badge is fitted exactly above the door handle. Under that badge you will see a screw. Remove that screw.
4) Now you can pop the bottom of the door panel with a flat screw driver.
5) Once the door panel is pop out. You can wiggle it by pulling the handle and then you can lift the bottom of door panel to make it loose and come out.
6) Once the door panel is out. Take care you don’t pull it as there are wires connected to it. So remove the wires from the door lock.
7) After the wires are removed fit the new door panel assembly and reconnect all the wires to their respective positions.
8) Then reconnect all the other parts which you removed in this procedure.
9) Fix all the screws to their positions.
10) Then check out the door panel.
on May 21, 2010 | Mercedes-Benz E350 Cars & Trucks
I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
May 14, 2010 | Dryers
On my babyliss type S47b, special screwdriver???
The screw may be triangular, or Torx (star pattern), or even 'pin-in-Torx', which all require special tools. They do it to prevent people from opening them up. But you can buy the tools, and for triangular screws I ground an old screwdriver down to match the shape!
Those screws are called 'Tamper Proof' or 'Tamper Resistant'. If you google those you'll find tool sets that will open dang near anything.
Mar 19, 2010 | BaByliss PRO Nano Titanium Hair Dryer
The heating coil isn't working. I am trying to get the screws out but they have triangular shaped indentations in the screws. Where do I get a screw driver bit to fit them?
the screws are tamper proof screws because it isn't meant to be user friendly. however if you have an old philips screwdriver and a dremel tool you can make a driver for those screws.
Oct 24, 2009 | Holmes Products HFH104 Ceramic Utility...
The on/off button comes off consequently machine isn't working
if you are handy the switch needs to be replaced. Soldering may be rquired and there is very little wire to pull. You can get a rocker switch at radio shack plus you need a triangular driver bit for base screws, It's really a poor design on a good grinder. You actually NOT have a switch and just hard wire it. I fixed mine for 3 bucks and an hours time
May 24, 2009 | Breville Conical Burr Coffee Grinder -...
Fixing a new electrical lead
Is it really triangular and not just 'star' shaped say in which case you can use a 'phillips' screw-driver.
If really triangular then you'll have to go to a specialist electrical shop and ask to borrow a correct tool.
The replacement of the burnt lead should be fairly easily done as long as you have already some experience in doing these kind of electrical jobs!!
May 21, 2008 | Kitchen Appliances - Others
Bonjour Caffe Froth plasatic part broken
My frother fell apart.
What order do these parts fit back together?
Am I missing a screw on the bottom.
Lost, any help out there?
Mar 21, 2008 | BonJour 7001-17 Caffe Froth Eiffel
Europiccola
Use (2). And you could back it off by 1/4 turn, rather than 1/2 turn I think. You want the piston to almost touch the screen at the bottom of its travel. You don't want the piston to push the screen out.
Fergus.
Dec 20, 2007 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
La Pavoni Caffe Mattina ESP-20 Coffee Maker Logo
35 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
