Question about ViewSonic VX910 19" LCD Monitor
The monitor says it is out of range. What does this mean
  • 591 Answers
This means that the computer is sending scan frequencies, horizontal and vertical, that the monitor can not process. Try using a lower resolution setting, ie 1024x768 or 800x600 and see if the problem goes away. Use your video card properties to change this setting.
Posted on May 06, 2010
Monitor say out of range
Just connect the monitor to another computer and change the screen resolution to 1024 x 768 or less. This means that the computer that is connected to that monitor, can not display the mode that your monitor is in right now.
Feb 27, 2012 | Princeton Digital Computers & Internet
"Out of Range" message appears and the icons are blurry.
Out of range means that you selected the resolution that your monitor does not support.
Your monitor works on 1440 x 900 / 75 Hz.
right click on blank space on desktop and select screen resolution. Put it on 1440x900.
Jun 19, 2010 | Envision G19LWK Monitor
Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Aug 24, 2009 | Soyo Computers & Internet
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Out Of Range
It means the LCD does not like the resolution or refresh signals from your video card. Try a resolution like 1024 x 768 at 60 or 72 Hz refresh.
Monitor Mike
Jan 03, 2009 | Star Logic 17" LCD Monitor
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Out of range displayed on monitor
Out of rang on a monitor has nothing to do with wireless.
Out of rang on a monitor means that the settings on the video signal are too high for it to show. The fix is to lower the video settings. You can start your computer in safe mode to change the settings if you don't have a better monitor to access it.
Jun 01, 2008 | NEC Computers & Internet
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
Open Questions:
ViewSonic VX910 19" LCD Monitor Logo
98 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
