Question about Hunter 27185 Remote Control
Hunter remote 85752 does not work
I replaced the battery in my 85752 remote control but it does not appear to be working. Do I need to reset the remote?
You probably need to re-sync the remote to the fan. To do this, turn the power off to the fan; and within ten seconds, hit the "3" button, then the "2", and then hold the 1 button until you hear a click. This should fix it. Good luck!
Posted on Nov 16, 2010
  • kolag1 Mar 21, 2011
    I didn't hear a "click", my remote still isn't working even though it use to.
    New Friend:
Let me add the the sync thing. I have a hunter 28424 ceiling fan
In my case I have a wall switch that kills the fan and the light. It seems that now the remote and the receiver get lost when I shut it off that way. I just found ( after banging my head against the wall for 3 weeks) that after turning the power on at the wall switch, the fan will be in the 1 or 2 speed. I have to then hit the 3 then the 2 then the 1 and then the zero for it to sync. When I hit the zero button, iI hear a click and then I can change the speed of the fan as well as turn the lights on. I was never, from day one, able to get the lights to stay on while on High. Low, no problem, but then again I am using CFLs and that might be the cause. I wa dreading having to pull it down to change out the receiver. Its mounted 15" up on a cathedral ceiling and it weighs a ton. I know I put it up there.
Hopefully this helps other out there and reading the ongoings withI Hunter i would say this is the last hunter fan iwill ever purchase. If you do need to have you receiver repaired these people might be able to do it. http://ceilingfanpartsonline.com/remote_receivers.html
I was just about to take the plunge when I found the fix.
Posted on Jun 19, 2015
Remote not working hunter 85752
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about this. http://electronicshelponline.blogspot.com/
Jul 29, 2014 | Televison & Video
How to reset harmony 650 for 'system error!' ?
If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
May 12, 2014 | Logitech Harmony 650 Remote Control
I need to reset a television remote
After battery replacement, you should set it up with the set-up codes to your device, because, as soon as you took out the batteries from its battery compartment, the remote control will reset to it factory settings. You should re-configure it with your device again.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Feb 09, 2014 | RCA Universal Remote Control
Device battery free universal remote
Probably needs a new receiver. Call 1-888-830-1326 with model of FAN.
Sep 29, 2013 | Hunter Dryers
Need 85752 hand held remote for ceiling fan top and bottom lights or universal
go to Home Depot or radio shack.
sincerely. God bless you
May 05, 2012 | Televison & Video
While going through the setup procedure the Set 3 was accidentally changed to Set 1. Any activation of the Control setting only makes the unit go to "Set 1" It appears to be locked up at that...
You can try resetting the remote itself (this is necessary whenever the batteries are replaced). Remove the batteries, as if to replace them, press any key on remote (to clear its buffer) then reinsert them. Next step, since your unit is 'Set 1' (or remote command mode 1 - DVD1/RC1) - you could (on the remote) press 1 and OK/ENTER together - hold them for 10 seconds, then release.
This should restore the remote to the unit. If it doesn't, a workshop service may be required to reset the unit internally, but at a cost. Try the remote battery reset first (even try using new batteries).
Apr 05, 2011 | Panasonic DMR-EH50S DVD Recorder
Harmony 880 Remote Control appears frozen
Hi!
You need to reset the remote control. Pull the battery out of the unit. To do this slide down the back cover off. Reinstall the battery after 2 minutes and it will reset the remote and you will be able to again use it.
Thanks for using FixYa and do rate the solution as fixya if found helpful.
Thanks
Rylee
Mar 27, 2009 | Logitech Harmony 880 LCD Remote Control
Remote appears frozen
I got the same issue with mine, and hooking to the computer and upgrading the firmware worked for me. I first had to take the bateries out and let it sit for 24 hours so it would loose the codes inside. No problems after that.
Jan 30, 2008 | Logitech Harmony 550 Remote Control
AIR CONDITIONER REMOTE
- Check if the battery is ok.
- Some remote control have reset button, you can find it at the front or back at the compartment of the battery push the rst button with pin or ballpen to reset it and try.
- Some remote control have selector switch in both remote control and at the board inside the unit. Try to transfer the switch button from A to B and also at the board inside the unit and reset the remote control and try.Or need to reconfigure the remote control to select the frequency.
- Try your remote control to other unit with same brand as yours to confirm if your remote control is really need a replacement. If it works then your receiver board in the unit is need a replacement. Or if wont work then you have to buy a new remote control. But if you have no budget then try to switch on the unit using emergency button to operate the unit.
Dec 26, 2007 | Heating & Cooling
Televison & Video Logo
2,600 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
