Question about Samsung X15 Notebook
My x15 plus cd rom has stopped working. I can I recover this?
  • 781 Answers
Your problem may have be a hardware problem or a firmware problem
before assuming that your optical drive has failed which requires to get the item replaced, try to do a firmware update as described on link below, review the info and make sure that it applies to your system first:
dvd drive no longer works correctly after update from samsumg update plus
Posted on May 06, 2010
After partitionning my hard disk, I loaded UBUNTU, and lost Windows. Any way to recover it?
It depends. If the "partitioning" used the entire disk-drive, rather than "preserving" the existing partition in which Windows was loaded, then you need to re-install Windows.
Either use the set of "System Restore" CD-ROM disks that were provided with your computer,
or telephone the manufacturer and order a replacement set of those disks (probably $20, plus $20 for overnight courier). Or, borrow a "retail" Windows XP CD-ROM, and install Windows,
using the 25-character product-key on the decal on the side/bottom of your computer.
Dec 13, 2010 | Canonical Ltd. Ubuntu
Tip
How to recover data from pen drive / memory card / hard disc /CD-ROM
Photorec is free way to recover lost data (formatted / corrupted) hard disks, CD-ROMs, memory cards (Compact Flash, Memory Stick, SecureDigital/SD, SmartMedia, Microdrive, MMC, etc.), USB memory drives, DD raw image, EnCase E01 image, etc. It ignores the file system, this way it works even if the file system is severely damaged.
You can download it from here.
on Apr 20, 2010 | Computers & Internet
Dvd player and Cd player does not work
This procedure is to be used as last resort. This is for software issues dealing with the CD-ROM or DVD-ROM drive. This procedure is designed to fix issues after removing Roxio Easy CD Creator but it may help other issues also. This procedure can fix an issue but can also cause issues, so don't use it till last resort before doing a re-install.
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
Jun 13, 2010 | Compaq Presario-Notebook 700 Series, 2500...
Samsung x15 plus Motherboard
It is possible but it's usually cheaper to replace the computer.
Mar 25, 2010 | Samsung X15 Notebook
Notebook Asus G2P Recovery cd 2/3 problem
check your hdd.. and cd rom drive..
Jun 20, 2009 | ASUS G2P Notebook
CD ROM STOPPED W0RKING
more than likely it went bad but check all your drivers for this hardware. go to start> my computer right click on my computer then go to properties on the drop down and click on it then go to>hardware>device manager and find the cd rom click the little plus sign on it and find troubleshoot icon that is all i can offer.
May 06, 2009 | Compaq Presario Modem/NIC Combo...
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
DVD wont play
maby bad ide cable might wann update firmware for cd players
Jan 09, 2008 | Intervideo WinDVD 4 Plus (WDVBF-7663-40RC)
Samsung x15 cd/dvd prob
Click start, run, type regedit
Navigate to this registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the "UpperFilters" and "LowerFilters" entries.
If you have more than one key with that number, use the first one.
Oct 12, 2007 | Samsung X15 Notebook
Samsung X15 Notebook Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
