Question about Refrigerators
WANT TO KNOW DATE OF MANUFACTURE. ALSO WHY IT ALTERNATELY WILL RUN WARM, THEN WILL BE COLD ENOUGH TO FREEZE FOOD IN THE REFRIDGERATOR COMPARTMENT?
  • 1,284 Answers
Hi, you have to know the name, model and serial number of your fridge, then contact the manufacturer who will then tell you the date of manufacture..
Secondly, the thermostat is in charge of regulating the heat on cool of every refrigerator and since your fridge is freezing up your food, you have a defective thermostat which needs o be changed..
Take care
Posted on May 06, 2010
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Everything is freezing in the refridgerator. The water dispenser will not put out water. We have taken the temperture to 0 then back to 5 and it still will freeze in the regular compartment.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 13, 2011 | GE Refrigerators
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
The refridgerator side of the unit is not staying cold enough. It is running about 48 degrees. This happened about 2 months ago, and I cleaned the coils and turned the refridgerator side of the thermostat...
If your model is the GS5SHAXN it has an electronic control for the temperatures. Not the typical thermostat. If it malfunctions either complete failure or an unstable control of temperatures. The part number is 2255233 at one place and part number 1016379 at another but the basic OEM number is the first one 2255233. I am going through some repair manuals to see if its possible something else might be causing this. I will return as soon as I can to see if that is the only reason that may be causing this. But with electronic controls I believe that it may be 48 degrees in the fresh food compartment is not safe. These controls are located in the fresh food section and connect with the temperature control. I'll be back soon, Sea Breeze
Nov 14, 2009 | Whirlpool GS5SHAXN Side by Side...
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Freezer is not freezing and refridgerator is not cold enough
have the freon checked for leaks, also check to make sure the compressor is coming on. If it comes on and is warm, boost freon. If the unit is not coming on properly, check the capasitors and compressor
Jul 24, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
