Question about LG LHD45EL Dehumidifier
Runs but not working
Ice is forming on the top/outside
  • LG Master
  • 43,501 Answers
Sometimes when they run extended periods of time the outter case can get very cold also...with no air moving over the outer case the condensation can freeze there....
This is a tip that I wrote that will help to understand it better...
Dehumidifier is Freezing up and not working http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 07, 2010
Testimonial: "thank you very much this helps"
3 Suggested Answers
  • 161 Answers
SOURCE: Running, but no water coming out. Is forming ice
Your machine has a sealed system leak and is low on freon. Read your owners manual and there should be a 5 year sealed system warranty. If so you will need your purchase receipt and call an authorized LG dealer for an exchange.
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: ice forms on top of the dehumidifier . it looks li...
Here is a tip that I wrote about that problem...
Dehumidifier2_bing.gif is Freezing up and not working
heatman101
Posted on May 25, 2010
How does it work
info???????????????????????????????????
http://home.howstuffworks.com/dehumidifier1.htm
Apr 04, 2015 | Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Ice started forming on top of unit and now it has shut off and won't restart. It hasn't been running efficiently for past few weeks. Can I fix it?
If the surrounding temperature is low enough the condensing elements of a dehumidifier ice up just like the cooling plates in a frig. Either reduce the power or raise the surrounding air temperature.
Jun 14, 2010 | LG LHD65EBL Dehumidifier
Ice forming on top front part of unit
usually, ice build up is caused by low refrigerant levels (a dehumidifier is essentially an air conditioner). depending on the unityou may or may not be able to service it. Some of these systems are sealed at the factory and a pierce valve is needed to add refrigerant to the system.
May 07, 2010 | Goldstar DH504EL Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Oct 09, 2009 | LG LHD45EL Dehumidifier
The dehumidifier freezes and ice forms on the filter in the back. It keeps running.
You are working it too hard. Back off the percentage. But first, let it thaw. Id be inclined to use a fan in the area. You might need two machnes in this space. Do not allow outside air into the space until you get it a little more dried out.
I hope this works for you
a
Sep 30, 2009 | Kenmore Dehumidifiers
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
LG LHD45EL Dehumidifier Logo
408 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
