Question about Hotpoint First Edition FEW10P Front Load Washer
My washer wont pump out the water
My washer wont pump out water and it half way up the door,ive checked as best i can theres no blockage in drain hose, please help
    Problem Solver:
  • 5 Answers
Try ur pipe that goes underneath ur sink 2 make sure its not blocked
Posted on Jul 07, 2010
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
The washer got stuck half way before program is finished
your drain pump isnt working or there is a blockage in the sump, drain hose or plumbing
Mar 30, 2010 | Zanussi ZWF1440 Front Load Washer
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Loud noise when the water is draining out and it locks the door and stops and wont let you open it
It is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag MAH6700AWW Neptune Front-Load...
It wont unlock after giving me the f04 code... cause it has water in it but i need to open it! it also the drum wont spin
sounds like your water pump has failed or blocked position your drain hose on the floor into a bucket or floor waste let water drain out you should be able to open door reposition drain hose in original position and try again if drain pump does not work check for blockage or replace faulty pump good luck
Nov 04, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
My washing machine works went it wants to its not drawing water ive cleaned the filter but dont know what else to do,
99 out of 100 washers tend not to drain water out due to blockage inside either waste water pipe (also called waste hose, drain hose and etc.) or circulation hose (the one between pump and drum). To check this lay the machine down on one of the side walls, remove the back cover (2 or 4 screws), disconnect hoses from the pump and ensure all blockages are cleaned away, all coins, small socks and other stuff is removed. Also you might want to clean the pump itself as at this point you're more than half-way through.
1 out of 100 drain malfunctions appear due to pump motor or the main PWB, but I bet that you won't need to replace neither of those.
Please let me know if there's something more I can help you with
Good luck
Jun 22, 2009 | Washing Machines
There is about 2 inches of water left at the bottom of the washer after the whole cycle runs. it wont drain
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
May 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Washer is not draing the water out
Check your drain on the washer. It is most likely clogged with debris.
Apr 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Hotpoint First Edition FEW10P Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
