Question about Dremel Variable - Speed Multipro Rotary Tool 395
I don't know how to change the bit on my dremel multipro rotary tool . . .I keep turning the gizmo but don't see anything getting smaller or lager.
  • 86 Answers
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
Posted on May 06, 2010
I need someone to tell me how to remove the entire attachment bit from the tool
dremel have a collet adaptor available to allow interchange of bits. They are available from dremel or hardware stores.
Feb 07, 2013 | Dremel Variable - Speed Multipro Rotary...
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How do i take the bit off of a dremel multipro model395 type 5
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Mar 16, 2010 | Dremel Variable - Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 in the middle of drilling sea glass and the collet and bit stop turning while the motor is still running fine! GRRRRR Thanks for any suggestions!
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Wires on switch
On my rotary tool the white wire goes on the left if pointed away from me. Hope this helps. Mamabear
Sep 18, 2008 | Dremel Variable - Speed Multipro Rotary...
How do I change bits????
there is a screw at the tip of the dremel, take it out and it is pretty basic after that
Aug 05, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
906 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
