Question about Tappan TMS062E1 Microwave Oven
Microwave just stopped working one minute working one minute no power no display (about 20 years old) can we troubleshoot and repair ourselves?
  • 67 Answers
Sounds like fuse may have blown..if light doesnt come on inside then that is possibly what is wrong..the fuse is inside the case and u have to take the outside off to get at it...make sure the power cord isnt plugged into the wall and do not touch anything else inside the unit ..there is a big capacitor inside that can give a very very bad shock....or the logic board is not good..if that is the case then it is not worth repairing
Posted on May 06, 2010
While microwaving it suddenly stopped working. No more display. Oven was made in 1996. It had been working without a light for several years.
yes im sure it doesn't need an interior light to work, but I would say 4 sure the only way id spend money on a repair of any appliance made in 96 (20 years old) is if it was part of a set that matched everything in the area , even then id think ******* it
Jan 19, 2016 | Sharp Microwave Ovens
LG Microwave ran empty for 20 minutes
I recommend you have a service man come in because it is more than a fuse, the keypad control board will need to be checked along with the rest of the system.
Apr 22, 2012 | LG Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave JE1650AA 002 Light, timer, panel display and beeper all work but the microwave nor the turntable work.
Hi worzelh,
When a microwave suddenly stops heating food, but still appears to run (the control electronics and light are usually a separate circuit), it's usually a defective/dead magnetron.
The turntable _may_ or may not be on the same circuit as the magnetron, that's hard to say without a wiring diagram or schematic.
Prices for replacement/repair will vary, you will need to find out what that service costs in your area before having enough information to decide on repair or replacement. If you tell the repairer that you suspect the magnetron, they should be able to quote you a fairly accurate estimate.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer ones may have more power/less energy wastage, etc.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | GE JE1650AA/WA/GA Microwave Oven
Samsung Microwave repair
This would be the turntable coupler, and you can get it here. The best way is to search by model number. If by chance you don't find it, call them at the number on their site.
You need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Samsung MD800SC Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
GE Microwave quit
Hats off to your 20 year old GE machine. That is the the longest lasting microwave I have heard of. When they finally go out, they are done, there is nothing left to even do with them. Most of the parts are obsolete. However you might find a appliance store that still has one similiar to yours in their backroom that they use for spare parts for those like you who might need it. You might take it to them to see if it is worth repair.
I can say this, after 20 long years, the machine will cost more to fix, and for what you will spend on repair, you can buy a different one that can also be energy effiecient.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
378 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
jdtech
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
