Question about JVC Televison & Video
Replaced bulb in unit. However it will not fire
Replaced bulb in unit. However it will not fire up. Power light is flashing.
  • 46 Answers
Make sure that the lamp enclosure did slide all the way in.Also ensure that the lamp door is closed.Resetting the lamp timer after a lamp is installed is also necessary.If after this your still having issues its possible your ballast could be malfunctioning
Posted on May 06, 2010
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
The power standby light flashes 3 times. checked the lamp door access switch, is ok what next?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. You might have replaced the bulb. But, have checked the ballast? Checked whether ballast board get voltage from the power board? Check these.
Jun 08, 2014 | Televison & Video
Can I replace the bulb in A Pentax flash?
Luke - Yes, it's technically possible to replace the bulb, but is not a good thing to try and do unless you are a skilled electronics technician. Flash units fire at very high voltages, and although an accidental shock would probably not be lethal, it would certainly be painful. I have worked on high-voltage power supplies of this type before, and must caution this is NOT FOR THE NOVICE to attempt. Finding a source for the bulb is the second issue, I searched my sources on the web for some time on your behalf and could not find one.
Lastly, consider that this same unit is available on eBay as of this writing at around $30 USD. I strongly recommend that you visit a local camera repair shop and see if they can fix it, or consider replacing it. I know, I hate to give up on anything either, but unless you have the skills and/or an experienced friend, it would seem prudent in this matter.
May 27, 2014 | Pentax Cameras
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
I replaced the bulb, closed the doors properly,try to turn on tv,
find the reset button and depress it for 30 secounds then fire the unit up again and leave to run for at least 1 hr
May 15, 2010 | Sony KDS-60A2000 60" HDTV
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
Sharp XR 10X lamp replacement issues
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Oct 01, 2008 | Sharp XR-10X Multimedia Projector
FLASH UNIT WON'T FIRE
Those Xenon flash tubes last for a long time. You likely need a new flash PCB (printed circuit board). Typically, the trigger coil is at fault when you get the ready light but no flash
Feb 08, 2008 | Nikon D50 Digital Camera
Televison & Video Logo
73 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
