Question about Maytag M6P09S2ACOM Air Conditioner
Room temp stays at 76 and will not get any colder even though unit seems to operate and compressor sounds like it turns on and fan blows and water drains . it is set to 60. room is about 300 sq ft
  • Maytag Master
  • 43,501 Answers
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
Posted on May 06, 2010
Portable A/C: Compressor runs intermittently and doesn't cool room
Your issue sounds like either a bad "pressure switch" or that the unit is low on "Freon." Either of these problems will cause the compressor to start and run shortly then compressor cuts off, then and repeats itself.
From your description It really does Not seem to be a "bad board in that unit" because the compressor is starting up, even though the compressor is not staying on long enough to cool said area.
Aug 15, 2016 | Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Our frigidaire window a/c unit (model faa067p7a) does not seem to be operating properly. There is no condensate forming anywhere (beneath the coils is dry and no evidence of water and there is no water...
It sounds like your unit is low on freon or the compressor is not kicking in. If the compressor kicks in you can hear it turn the unit on fan only or turn the thermostat off then turn the unit to demand cool you should hear a hum even vibration when the unit kicks in. If there is no audible hum ect... your compressor is probably not kicking in. The selector switch the temp switch the capacitor for the compressor or the compressor its self could be bad. good luck if you need to know how to test any of the above let us know
Aug 11, 2010 | Frigidaire Compact Air Conditioner
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
Hi there. I have a problem with my Rheem Classic
my friend it sounds like you have a bad motor the compressor will lock out either on hi pressure or internal overload start with the outdoor motor good luck
Jul 19, 2009 | Heating & Cooling
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Heats for 15 - 20 mins then blows cool air
If the outdoor unit is in defrost mode the compressor will be running but the outdoor fan will not. You may even see some steam rising from the coils. This mode is to prevent frost or ice build up on the outdoor coil. Essentially it goes into cooling mode w/o the outdoor fan running.
Mar 05, 2009 | Goodman GPC1342H21A Air Conditioner
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Maytag M6P09S2ACOM Air Conditioner Logo
246 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
