Question about EliteGroup 741GX-M Motherboard
Boot up problem: No Bios reading
I have a 741gx-m motherboard and the problem is that when i start the computer the cpu fan,the video card fan run and the chassis fan ran, but the system bios won't read or even the hdd doesn't read at all. what's should be the problem of this computer. pls do answer back. thanks!
[email protected]
Try to unplug unnecessary hardware.. just plug in the monitor to video card, power, and the memory.. unplug the IDE cable or SATA and also the USB devices... Observe if your system will boot. sometimes hardware damages prevent your system to boot..
Posted on Mar 27, 2008
SOURCE:
Cpu fan failed
bench test the fan
or could be just dust build up
Apr 07, 2017 | HP Pavilion 515n (DC471A#ABA) PC Desktop
After power on Fans are running but no Videosignal, no bios startup.
Could be 3 things Memory or CPU or Powersupply. are you getting any beeps if so how many, how long. try taking all the memory out and powering up see if it beeps if so try to put one stick of memory in at a time and see if it will boot. if you get no beeps with memory out check powersupply some PS's have a red switch on back for current input. switch back and fourth about 20 times uning a pen and set it to the right current for you location. put ram back in see if it will boot if not its trial and error of the PS and the CPU replacement and it still could be the RAM giving false readings. yea i know sounds like a ball of fun.
Feb 24, 2010 | Intel D915GAV Motherboard
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
Motherboard problem
Have you tried a new power supply???
You may have a high end video card installed, which will need a big
power supply.
Try removing all parts except the CPU and video card, your system
should still boot to the bios post screen, If still no go try a new video card, cpu. you will need to keep swapping parts around tell you find out witch one is causing you the prob, its the only way
to sort out a hard ware issue.
Hope this helps
Have a nice day.
Dec 22, 2008 | ASUS A8N-SLI Deluxe Motherboard
Boot Issues
Check the memory and the video.
Jul 20, 2008 | Intel Motherboard
Computer will not boot
Bios is erased, clear cmos thru motherboard; pins
Apr 05, 2008 | EliteGroup P4VXASD2 Motherboard
Bios unknow flash type doesn't find A drive or hdd
hi...!!!
If you have a PM-599LMR (M599LMR) motherboard or PG-5517A PreSystem you may not be able to update your BIOS. A batch of BIOS chips used on these motherboards was accidentally WRITE-PROTECTED when it was originally programmed. Any attempts to update the BIOS on one of these write-protected BIOS chips will cause the system to become unusable. The only way to restore your computer is with the original BIOS and the BIOS recovery procedure above.
Feb 02, 2008 | EliteGroup 741GX-M Motherboard
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Monitor not Running(shows only orange light)
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Dec 26, 2006 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Your computer has memory problems. First check the video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad or they are mismatched .The CAS latency has to be the same and compatible with your M/B. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Sep 25, 2006 | EliteGroup 741GX-M Motherboard
EliteGroup 741GX-M Motherboard Logo
259 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
