Question about LG Flatron F700B 17" CRT Monitor
Monitor screen is out of shape!
I tried finding LG Flatron E700SH, but couldn't, May be its outdated or not in this data base. Anyway, my screen is out of alignment. All 4 edges of the screen are fixed on their own position. I tried all I could, tried aligning them with the help of 'MENU-->SHAPE, which has many different angles of adjusting the screen, but it just doesn't become neither a perfect square/rectangle, nor a perfect bulge. Please help me fix this problem. Thanks!
D'
  • teencracker Nov 24, 2008
    I am having trouble configuring my monitor's shape settings.
Lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
What is default monitor screen setting LG flatron e700sh
1280x1024 resolution
I would try using a 60hz refresh rate though it does state the monitor will support up to 85hz
Feb 18, 2011 | LG Flatron F700B 17" CRT Monitor
My monitor is LG FLATRON E700SH out of shape it is not getting adjusted can u please give me the perfect shape specifications
I have a problem of setting screen onto moniter ... So just suggest me what is Screen Position , Shape Size to me
Oct 08, 2010 | LG Flatron F700B 17" CRT Monitor
LG FLATRON E700SH problem wid it is that .its led is flickering dimmly but screen is black out ..? buta sometime after 20m 45 minutes the monitors starts working .but some time it doesnt.??????????
The picture board on your monitor is malfunctioning, since the power led or button is on, but the screen is black out, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | LG Flatron Ez T910BU 19" CRT Monitor
My monitor display size probs
u can adjust the screen appearance by presssing the buttons on the front...do a hit and try as i am not sure which buttons do what function in ur monitor and how they are positioned...normaly it will have function/up/down/set etc..eash option will increase, decrease, move up, move down, left, right, zoom out etc
Dec 24, 2009 | LG Flatron F700B 17" CRT Monitor
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
LG FLATRON E700SH is not displaying RED color
there is ovbiously a fault with the monitor and w ould be best if you bought a new up to date monitor then if any faults consist with that one you could just take it back
Dec 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Open back cover of lg E700SH
there is a lock system to this monitor put crt front portion on table take a smallest screwdriver insert it into the narrow gap and pull the cover upperside it will open there are two gaps anyone you can try
Nov 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
LG Flatron F700B 17" CRT Monitor Logo
554 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
