Question about Armitron Two Tone Sports Watch
The day goes into another language and I would like to know how to make it return into English please.
    President:
  • 2,501 Answers
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Posted on May 07, 2010
I replaced the battery in my sharp watch and now it will only show the days in Spanish instead of English. How do I reset it to English?
The crown that setc the watch has two positions pull it out one position and you should be able to rotate to the proper language. One Way operates that date the opposite direction operate the day.
Good luck hope this helps
Jun 02, 2016 | Watches
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
Apr 26, 2012 | Polar FT4 Watch
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
May 26, 2011 | Diesel Watch Style # DZ4067
Ref G3002-Batt:UC-364 PO:01092. Rotary quartz watch. I require to alter the date and day feature which has english and european days. I can alter the time by pulling the handle out which is shielded in...
Your watch should have a position in between home and fully out but it sounds as if your watch is like mine, where I cannot detect the position (i.e no click or feeling any detent).
Try to pull the crown wheel out a little and turn it. (the day and date change feature is in this middle position).
The english days can be achieved by turning the wheel until the desired day shows (it alternates between english and another language).
Have patience and keep trying until you get the feel for the correct position!
Mar 23, 2011 | Rotary Watches
My casio wave ceptor 3054 wv-58a is not working right. I live in Phoenix,Arizona and we don't observe daylight savings time and when I went to take it out of dst mode the day of the week is in a foreign...
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
Mar 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need to change language on day display from French to english.
1)Rotate crown fast - to change into "date + day" mode
2)crown up
3)fast rotation or the crown = changing the language (en, spain, france, german)
(when rotate crown slowly = you'll change year).
Or read full manual where this procedure are written in exact form:
http://www.tagheuer.com/_documents/manuals/EI2254_en.pdf
Feb 10, 2011 | Tag Heuer 2000 Classic Multigraph...
On my sports 50 it stops if it is off of my wrist for 14 hours . Also I dont know how to change the day sign to english
This is obviously unsatisfactory and I can understand your problem. Even spring driven automatic watches will run for 2 - 3 days when not worn.
Your watch can either be charged by use (i.e. wearing it) or by winding the crown wheel, although there seem to be a variety on kinetic watches and it is not clear if all of them can be wound by hand (mine can't but it goes to sleep after two days and can stay in this mode for 3 months and re-starts when it is worn!)
For a fully description of the kinetic operation go to http://www.seikowatches.com/technology/kinetic/kinetic_dd.html and there you will will see a choice of kinetic watches.
You can also access the instruction manual list to check out how your watch is intended to operate. Some watches indicate days in two languages (as yours appears to do) and you can select the correct day by pulling the crown wheel to the middle position where you generally change the date by rotating it forward and the day by turning it backward. When turning it backward, you should see and alternative day and you should stop at this position. The watch will continue with the same language after this.
If this does not work, then you should be able to find out the day sign after reading the instructions.
If your watch is new and after reading all the literature you still cannot sort out how to make your watch run for a longer period, then contact the maker who should be able to help.
Jan 02, 2011 | Seiko Kinetic watch
Nicolet Men's Metrosphere Swiss Automatic Stainless Steel Watch the day is not in English, currently it shows MIE, can I set this to show the days in english?
I don't know this watch specifically but typically the following applies:
To set the day/date you set the crown (winder) to the first position (second posn is "set hands) i.e. pull out one stop, and rotate winder eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Jul 17, 2009 | Watches
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Armitron Two Tone Sports Watch Logo
Top Armitron Watches Experts
Michael Vincent Cruz
Jimmy Accardi
Are you an Armitron Watch Expert? Answer questions, earn points and help others
