I have a few dB Technologies M12-4 powered speakers with the same problem, which leads me to believe it's a design flaw. The sound is intermittent. When I press on the right side of the amp, the sound comes back. I've checked the components and solder points on the transistors, connectors, etc, but can't find the problem. Any ideas or info I may not have? Thanks, Gene
  • Audio Player... Master
  • 5,047 Answers
It still sounds like a bad soldering joint or connection somewhere!
You may have to resolder all the joints just to find it. Also look at the PC board for hairline cracks in the tracks. You might need a magnifying glass for this. The only other thing I can think of is you might be acting as an earth link when you press on it.
Posted on May 06, 2010
Testimonial: "Thanks a lot for your time and expertise! I've re-soldered many of the joints, but will follow your advice and check everything else out with a good magnifier. I was also thinking it could be a grounding problem. With the same problem happening with more than one unit, I was hoping that maybe it was a common problem that was known with this particular cabinet. Again, thanks for your time! Gene "
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Protect keeps coming up when volume is over 34 db and mute light comes on. and then switches itself off and says protect
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Jul 25, 2011 | Audio Players & Recorders
The MPM4130X works for several months then decides to blow fuses. This has happened twice now, so I suspect a design flaw. If I could get a schematic, I could possibly design in a little more margin to...
If ONLY the fuse blows and replacing it restores operation I would suspect an operational problem. Possibilities... does a speaker lead get grounded? Can the microphones hear the speakers? This latter is important because a supersonic feedback could occur that you can't hear but overheats the amplifiers. DO NOT boost the highs with EQ to avoid this possibility. Always check that the speaker leads are secure before power the unit up. 1/4 inch plugs/jacks are notorious as speaker connections due to the shorting possibility. You MAY have to go through the manufacturer to get schematic.
Jul 01, 2011 | Nady Systems Nady MPM-4130 PA System
Recently my outlets went out in my Living Room and ever since then my speakers cannot go above a certain db range without shorting? Is there anything I can do at home to fix this problem? Prior to this, I...
Shorting out? If they short out they will never run again.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Try it on outlets that don't have any problems. If THAT works get the L/R outlets looked at by a trained electrician.
Jun 21, 2011 | Sharp CD-DD4500 System
Hi r these good speakers?
Power Handling (Peak) 300W , Power Handling (Continuous) 150W , Frequency Response 25Hz-22Khz , Crossover Slope @ 4.5Khz 24Db/Octave , Efficiency (1 Watt/1 Meter) 93 Db , Impedance 4 Ohm .
what this means is that the speakers are designed for a car stereo alone, NOT stock stereo as it wont have enough power. See the one 50w x 4 ,, yeah its designed for those. All and all its not a bad deal.
Mar 31, 2011 | Planet Audio BB65PRO Car Speaker
Greetings. My MG 250 DFX Marshall 100W amp behaves strangely... I had some problems with it lately. I've been using it for a few years in my flat, so it has not been used extensively in terms of power...
I believe the design of this results in what you are seeing... Check each speaker INDIVIDUALLY plugged into the MAIN output as plugging into the second jack shifts the tap of the output transformer to the 4 ohm tap which results in a 6 Db drop but now you have two speakers... the apparent level change will be almost unnoticeable.. Do comparision of the speakers individually using the MAIN jack. This is just the characteristics of the beast...
Jan 11, 2011 | Marshall Amplification Marshall MG250DFX...
My speakers got no sound but headunit is on. fm / cd all no sound from my speaker
you might have one of the speaker leads grounded, which can cause some stereos to short to prevent damage... check your speaker connections and disconnect power to the headunit for about 5 min then repower up.
Oct 18, 2009 | DB Drive SP10.1 Car Subwoofer
Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Dec 31, 2007 | DB Drive A460 Car Audio Amplifier
No Woof
If these are Mission 780s your talking about, you're not the only one. The woofers supplied with the speakers originally have a known design/manufacturing flaw causing them to go "open circuit" after a few years use. The good news is that IAG (who now own Mission) can supply you with a pair of replacements for about £45 plus postage. (You'd be forgiven for thinking they should supply the replacements for free given the cost of these speakers new and the fact this is a design/manufacturing fault). Replacing your woofers is easy. Take off the front baffle. Remove the four rubber plugs that the baffle attaches too, and take out the 4 screws you'll find behind them. Now ease off the plastic moulded front pannel. Remove the four screws holding the woofer in place. Pull the spade connectors from their tags on the back of the speaker. Put the new woofer in by following this proceedure in reverse.
Aug 03, 2006 | Mission 780 Main / Stereo Speaker
 Grubhead
Grubhead
