Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
We are smelling too much ozone from a F300E 1001, help! thanks, colin
  • Honeywell Master
  • 43,501 Answers
The easiest way to lower that is to place it on a timer so that it does not run so much... other then that you have a unit that is too big for the area of space that you have and you really need a smaller unit...
so just limit the run time...
heatman101
Posted on May 07, 2010
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
How do I clean the glass plates in the flair living air f141023
Usually a mild cleanser is all you should need. In some extreme examples you to clean the contact area and the contact itself for ptting, and then lightly rub the mesh with 600 grit finishing paper to break up the silica that may have formed.
Ozone itself is a power oxidizer, it will clean the air in an enclosed room. Excessive Ozone "can" be a problem that usually manifests itself as upper respiratory irritation. Lower levels oxidize with pollutants and you never know it's there.
Ozone will also attack eurethane foams, foam rubber, and elastic rubber. So speaker surrounds usually decompose, and headliners in cars often fall apart about 6 months after exposure-used car dealers use them a great deal to kill residual tar and soot from smokers.
Feb 05, 2012 | Ecoquest Air Purifiers
I no longer smell the ozone smell that i used too.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers.
May 29, 2010 | Ecoquest Breeze AT Living Air Purifier
No ozone smell
May 19, 2010 | Ecoquest Flair Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
May 10, 2010 | Alpine Air XL-15 Air Purifier
Ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Nov 15, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
I have the enviracaire f300e 1001 in a house i just bought. i cleaned the filters. whenever the furnace turns on a buzzing comes from the unit. is this normal? the thermostat also flashes "filter".
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
Oct 29, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Last night for the first time the machine is emitting a gaseous smelling odor. At first we thought it was coming from the house, electrical or outside. Not finding anything which would generate this...
The odor is trace amounts of ozone. I hate the smell myself, some people love it. Most common cause is a short in the cells. Can you hear any arcing noises?
Did you clean it recently. The ozone can be reduced by making a change in the power head. What is the model number and date code........Should be like, F300Aor E1625, The date code is a four digit numbe like.....0904. Both can be found on the back of the aircleaner door.
May 22, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
When ionizer is on even
Hi willy,
The ionizer itself shouldn't smell. I wonder if you're smelling O3 (aka ozone or activated oxygen), or if there's a short-circuit of some kind that is causing electrical components to overheat/burn. Burning electronics and singed hair smell more alike than ozone (which isn't the same as ionization, incidentally.
Write back with more details if you can, preferably with any details about your observations.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 17, 2008 | Ecoquest Flair Air Purifier
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
143 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
