Question about Polaroid FLM-3225 32 in. LCD Television
How do i get the tv to get pip with a cable box and only one coaxle cable input on the tv
    President:
  • 196 Answers
Use the coaxial cable + conect the yellow, red and white cable to video input in tv.
Posted on May 06, 2010
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
How to get cable signal thru my TV
You must use a coaxle cable to the RF connector located on your TV. You must be in the option of TV/ cable (input button on remote). Be sure to program your auto channels for viewing.This connection is fine if you are not using a digital box. If you have the digital box, be sure you have the proper input (input 1, input 2, input etc.) on your TV. Use the optional, red, white and yellow rca cables,in this case. Remember, press options, input 1 or input 2 etc. Hope this will clue you in to proper programming. Thanks for asking and show all hands of support!
Aug 03, 2011 | Westinghouse Televison & Video
Help with Hitachi Audio Video Center (AVC80U)
okay so it doesn't need a remote control.............. The AVC08U should register immediately with the tv, the box itself has a bad HDMI out.
Dec 07, 2009 | Televison & Video
When hooking my direct tv into the coaxl in it does not work ? When I use the AV cables it works. and I do try all inputs.What can I do
If the coax RF OUTPUT cable of the direct TV BOX is set to channel 3, the the TV will have to be SET TO TV CH3.
Nov 02, 2009 | Olevia LT32HVM 32 in. LCD Television
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
Hooking up my VCR
OK If you are running cable you would plug cable box into VCR then VCR out to the TV input red/white/yellow/ or a coaxl cable (like the one the cable companys Good luck and Thank you for using FixYa.
Dec 17, 2008 | Emerson EWV401 S-VHS VCR
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
Just bought Samsung HT-tz515. how do I hook up my incoming cable television to teh system? I do not have a cable box. Can I get a splitter or other connection or do I need to get an intermediary such as...
simply buy an input selector, one with coaxle input along with rca or svideo or hdmi output then hook your cable coaxle to the input and run rca cable to the new system, very simple and works great
Aug 10, 2008 | Samsung Audio Players & Recorders
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
Polaroid FLM-3225 32 in. LCD Television Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
