Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
My dryer has power, but it sounds like its jammed
  • Whirlpool Master
  • 43,501 Answers
No that's what it sounds like if the motor is going bad...
There can be many reasons why your dryermy dryer has power, but it sounds like its jammed - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 06, 2010
WHY DOES THE DRYER ONLY HUM WHEN I TURN IT ON?
If the hum sounds like the motor is running, you may have a broken belt. If it sounds like the motor is jammed you may have a locked up motor or something got through the lint screen area and has jammed the fan. Hope this helps.
Aug 05, 2014 | Whirlpool Dryers
WHY DOES MY WIRLPOOL DRYER MAKE A HUMMING SOUND WHEN TURNED ON
Sounds like there's something in the lower wheel jamming the motor . GOOD LUCK APPLIANCES R EN
May 21, 2014 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
My kelvinator dryer began to squeak loudly and now it will not run. When I push the start button, there is a sound, but the dryer would not work.
sounds like the barrel has jammed try turning it by hand to see if its jammed if so then it will need to be serviced by a lic tech if the barrel is free turning then i would say it has broken its belt the sqeaky noise would be its bearings wearing out putting the barrel out of alyghnment this too will need replacing
merry christmas
Dec 22, 2010 | Dryers
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Frigidaire sensor gas dryer will not turn on, power supply and breakers ok, Makes a noise like it wants to turn on. Drum is free and moveable.
if you can move the drum by hand and it's humming it sounds like you have a bad motor or the belt broke and is jamming the motor and that's why the drum moves,you have to get in there and check it out,open the door and the model number should be there,next time send model number
Apr 13, 2010 | Frigidaire FGQ332ES Gas Dryer
Dryer wont spin, motor making humming sound
sounds like the motor is bad,try turning the drum by hand,if it's hard to turn there could be something stuck in the blower wheel or the belt is jammed on something or the motor is bad
Feb 19, 2010 | Kenmore 800 7983 Dryer
Dryer makes a humming sound and nothing else
Sounds like your tumbler motor is stuck. Try moving the inside of the dryer. Does it turn freely? If it does then the motor could be defective. If not the dryer tumbler could be jammed.
Dec 19, 2009 | Whirlpool Dryers
Whirlpool Dryer LER7646EQ1 Motor?
Could be something jamming the fan blade but if the motor shaft turns freely then your motor is bad.
May 28, 2009 | Whirlpool LER7646E Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
71 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
