Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I have a broken Belt, that turns the brushes. Can't find anywhere.
  • 755 Answers
chrispurs1
  • 372 Answers
SOURCE: Brush on Dyson does not turn ....belt not broken
Hi.
Your machine has 2 belts one goes clutch to brush roller second is motor to clutch.
You need to remove the clutch unit from the machine & replace the motor to clutch belt.
Its A lot to try and explain try this site for help.
http://dysonmanuals.llc.nu/
Posted on Jan 11, 2009
  • 3 Answers
SOURCE: brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Posted on Jul 28, 2009
Coleman37
  • 337 Answers
SOURCE: motor turns on, but brush won't turn. belt is not broken
Sometimes hair and debris get in the end of the rollers and keep them from turning. Also, the bearings can become corroded and stick. Try removing the rollers and check for any debris and remove it. If the bearings are stuck, you can spray some lubricant or WD40 or them and try to free them up. On occasion the belt can come off of the motor. You can turn the unit over and see if the belt is moving over the roller. Good luck and let us know how you made out.
Posted on Mar 04, 2010
Samyfam
  • 378 Answers
SOURCE: brush won't turn but belt is not broken
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the clutch to the brush bar. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay2_bing.gif reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Posted on Apr 27, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Posted on Sep 30, 2010
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
Brush is not turning and water is not coming out when lever is squeezed
You may have a broken brush belt they break far too easily. Turn it over and look around the sides of the brush for a broken rubber belt.
Dec 08, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuum turns on but the brush is not rotating
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Sep 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Bissell pet hair eraser model #3920. It's been working great until last night. I went to use it and the brush won't spin. It also smells like it's burning. I checked the belt and it looks fine,...
- Remove the access panel, which is on the bottom of the machine. There are 4 tabs to lift on the access panel to remove. Start with tab 1 then 2-4 tabs.
- Check the brush, and belt for any damage. Clean off any debris on the brush.
-The belt may not be broken but may show signs of wear. If belt is broken or shows signs of wear, replace belt.
Aug 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Brushes dont spin
You will have a slipping or broken belt turn brush by hand have machine off check if belt is broken if it is replace with new. undo brush holder and brushes should come out there may be more screws to undo after the brush holder but very simple job. good luck
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brush not turning
The belt doesn't have to be broken to be non-functioning. If the belt is intact but stretched it won't turn the brush. You can get belts here:
Dyson DC14 Belts
Feb 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Brush froze up and keeps breaking belts
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
152 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
