I just bought a MaXLine II 250GB HD but my computer is not recognizing it.
  • MrsBott4u Mar 28, 2008
    Thank you for your response. It is the only drive and the jumpers are set to master. Any add'l help is appreciated!!
  • 667 Answers
If you've got it connected to another hard drive make sure you have it set as a slave. If you've got it connected all by itself make sure you have it set as a master. If those are ok or that's the way you had it setup just add a comment to this abd I'll br glad to come back to help you out. If this fixed you up please rate a big 4 fix ya. I'll be back to check on you later.
Posted on Mar 28, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 28, 2008
    Please tell me make and model # of pc and motherboard if you know it would be vey helpful. Thanks.
Hi my problem is i have maxtor maxline plus ii 250gb i put it like external hard disk but its not not recognized, i try with some tools to fix it because some answers say its mbr its the probleme of that...
Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Mar 28, 2011 | Maxtor MaXLine Plus II 250 GB Hard Drive
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Windows XP can't see SATA Drive
turn of Ahci mode from your bios settings and if there is also some sata configuration then turn those off also then check...
Dont forget to rate
Sep 08, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
I need to set jumpers on hard drive Maxtor Maxline plus II y653z5le as a secondary drive. How do i do that?
on the drive there should be a diagram for how to set the jumper settings. you want to set it to slave.
Jun 13, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Hard drive wont show up
change the jumpers to slave if it is on the same cable as the master should show up
if it is set now on master it wont show up
Feb 23, 2009 | Maxtor MaXLine Plus II 250GB 7200 RPM...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Oct 25, 2008 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
