RCA TH1101 MP3 Player Logo
Posted on Mar 27, 2008
Help me when it is turned on all you get is pearl with some outline thats it it stays on that screen
  • blindstitch Apr 21, 2008
    i have a rca pearl TH1101 mp3 player that i brought for my son on christmas and it hasn't worked since i got it. I just didnt' take it back because i lost the reciept to it. But i want to know what does it means when you turn it on and it says no files! I have used the disk that came along with it,but it still say no file.this is from [email protected]
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 29, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
64718
Points
46
Sound like u need to up grade the firmware or format the mp3 player
My RCA pearl mp3 player wont turn on. It just goes to the first screen and stays there.
I loved my Pearl but I misused it in a way that destroyed the SW inside. Study the user manual closely.
1helpful
I took out the battery and place it back in, now there's a lil black clock showing off an on then disappears. When i flip the phone open app ERROR 523 and Reset shows up on the screen
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information before hand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
1helpful
App 523 error blackberry pearl 8220
Hi, You can reset the phone to clear the error
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Thanks.
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
4helpful
My blackberry pearl flip the sms msg icon is missing. i can'y find it. tried everything already. switch on n off. pls pls help
H,you can reset the phone,might restore lost icons.
Note: you will have to backup data cause data might be lost when reset is done.
Thanks.
When my Pealr powers on the screen only stays lit few seconds
You can try a master reset which your provider will be able to provide the steps to you on how to do it, or the manufacturer's website. if a reset doesn't fix it than you need to get a new phone through your replacement options for this is a device issue.
When turning on my blackberry pearl 8120 all i
We suggest you to reinstall the software and check the handheld. If you face the same problem even after reinstalling the software, you need to visit the outlet where you have purchased the handheld to service the handheld
Missed calls stay on external screen
you can try to turn off your phone and turn it on after 5 min
My rca pearl 1611 mp3 player
This probably wont be a big help but try changing the battery
3answers
My rca pearl
Reset by removing/reinserting battery
You may also have to reformat the player or upgrade the firmware if the problem persists.
-Tha Mp3 Doctor
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
