Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
When sucking up dirt I can feel it hitting my feet
I have a Hoover Mach 3 only 2months old. When I sweep up the dirt I can see it going into the container, but I also feel some of it hitting my feet. It is coming out the back of the sweeper. What is this about.
    President:
  • 1,673 Answers
You could have a partial clog eihter in the hose or in the dirt inlet by the brush roll. If can't figure it out, you have a years warranty on this, take it to a warranty repair shop.
Posted on Mar 27, 2008
I have a Hoover Nano Cyclonic that doesn't use bags. My daughter took the entire bottom apart because it wasn't sucking up. So she tried to clear everything and also TRIED to put it back together.
You may have a clog in there somewhere,
but still enough suction to pick some dirt up but it doesn't get sucked into the dirt cup and falls out when you turn it off. If your filters are over a year old or not maintained or cleaned frequently they may be restricting the air flow which can lead to clogs.
Jan 31, 2017 | Hoover Vacuums
My vacuum throws dirt out and hits my feet.
Hi Peggy,
I'm sorry to hear you're having difficulties with your DC07. From what you described, it sounds as if your machine has a blockage. The filter may also need a wash.
Although I note you already took it apart, please follow the steps shown in our online Support guide to make sure you haven't missed anything:
http://www.dyson.co.uk/support/dc07/dc07-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. We'd recommend using cold water without detergent. Leave the filter somewhere warm to dry, such as in an airing cupboard or by a radiator, for at least 12 hours, and make sure you don't replace the filter in the machine before it's totally dry.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 27, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Hoover UH70040W Wind tunnell mach cyclonic has stopped sucking up debris. At the brushes you feel no suction and when you disconnect the tube on the side it has some suction but not much at all. The...
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Mar 31, 2011 | Hoover UH70040W Bagless Upright Cyclonic...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
While vacuuming, debris spits out the back.
that's normal. try lowering the heght adjustment
Mar 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Suction problems
sounds like a clog right near the front
Nov 14, 2008 | Hoover Elite U5061-900 Bagged Upright...
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
117 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
