Question about Canon MultiPASS F50 All-In-One InkJet Printer
Will not copy B & W document. Have put in new
Will not print B & W document : comes out blank. Have put in new BLK ink cartridge, cleaned heads. Ran print test and column A is not there.
No problem printing color document.
Thank you
Jacques
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
Canon mp830 cannot print is printing only in color. Put in new black BK8 and PGBK5, but just prints blanks
Could have ruined the head from not proper cooling from the ink supply.
Try to clean the head using 8 oz. hot water (preferably distilled) and 1 oz. ammonia.
Make sure the intake ports are submerged for 30=45 minutes. Dry the head completely and re-install.
Gently tap the PGI5 BLK on a towel and make sure ink comes out.
If so do a deep clean and a head alignment page.
If nopt you may need a print head that I can supply.
Thank you fo0r using Fixya
Aug 27, 2014 | Canon PIXMA MP830 All-In-One InkJet...
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
While I copy documents, all documents go through and printer sounds like it is printing but the sheet comes out blank.
Make sure:
  • The ink cartridges are not empty.
  • If you have put in new ones make sure you have removed covers from both connections and nozzles.
Do a head cleaning on the printer:
  1. Push "Ink"
  2. Select "Cleaning" by pushing up and down arrows.
  3. Push "Menu/Set"
  4. Select "Black","Color" or "All"
  5. Push "Menu/Set" to start the cleaning.
Can do the procedure up to 5 times.
As a last resort you could take out the cartridges and rinse the nozzles under the tap water for a few seconds, wipe the cartridges dry and put them back in the printer.
If none of the steps help contact Brother for further assistance.
BR
Aug 27, 2010 | Brother MFC-3240C All-In-One InkJet...
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Mar 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MULTIPASS MP730
I just replaced my blk ink cartridge also, nothing prints
Jul 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
When I put an original on the glass to copy, copies come out blank but cartridge has not run out
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity and therefore it is not taking an accurate picture.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. Do you have the same issue when scanning?
If it happens when you scan and it is plugged into the wall and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jul 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Canon MultiPASS F50 All-In-One InkJet Printer Logo
165 people viewed this question
old marine
old marine
