Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I'm unable to set GE Profile Arctica ridge to recommended temp
The fridge was working fine until this morning when the double door fridge and refrigerator temp went up and now I'm unable to set it to the recommended temperatures.
Please help!
  • GE Master
  • 4,654 Answers
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
Posted on May 07, 2010
  • John Tripp
    John Tripp May 07, 2010
    Please tell me if your temperature controls appear to be working normally also. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
  • John Tripp
    John Tripp May 13, 2010
    Thanks for the Rate! I normally do not hear from people unless they write me or someone other than myself writes something that responds to your question. I think from here I will post a chain of events addition to an existing web page that will give you and others a check list to go through for Profiles and Articas. These refrigerators are not as much complex in design but sensitive to simple minute conditions like for example leaving the freezer door ajar for a few hours will set it off like your symptons and disconnecting power will reset that problem. Or blocking a themistor with a product stored near the thermistor. There is a Service Manual for your model and even if it dose not look the same most GE Profile PSW26P or almost all have and fall under the same wiring and chain of events. Click on the wiring diagram on this page=> GE ARTICA PROFILE TECHNICAL INFORMATION
    it will be the second largest photo a layout of your wiring. When you click on that it should open in a new tab. Save to your computer and study that manual. Feel free to contact me at any time through my website. I am not just refrigerators, Again Thanks, Sea Breeze
    Appliance 911
Ok the fridge door is to low it is not shutting the liht off, reajust the door ,,simple solution...they some times fall down alittle. the light bulbs are heating up the fridgedone!!!!
Posted on May 13, 2010
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica Refrigerator Displays OFF PSS29NGNAWW
Sadly i would say the board is malfunctioning and needs replacement. There is nothing in the fridge/ freezer that if malfunctions can cause that.
Sep 21, 2009 | GE Profile PCF25PGW Side by Side...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Hi - I have a GE Profile Arctica model #PSC23NHMC. The fridge side works fine. The freezer side runs warm. I set the temp to recommended 0deg but it averages from 9deg to 16 deg. I had a local authorized...
unfortunately these systems are very expensive to repair and most shops will not service them if repairs cost more than a new unit. However you could make sure to keep the coils clean and adjust the thermostat to its coldest setting to get as much life from this one before buying another one. hope this helps and good luck.
May 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
552 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
