Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Freezer side works, other side does not cool
We have a ten year old Gallery model that quit cooling only on the
non-freezer part. the freezer side hold the temp at 10 degrees.
What can we check to see if it will start cooling again?
  • Frigidaire Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 06, 2010
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Our freezer quit working tonite..hss251fmdww model # hotpoint side by side
My new years gift was for my Hotpoint HSS25IFMD to stop cooling. Lack of any cooling is typically a bad compressor. This model refrigerator was made in 2002. Seems like the compressors are designed to fail within a year or two after the warranty expires.
Dec 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a ten year old Whirlpool top freezer refrigerator that was recently repaired for non cooling. I believe my landlord replaced the thermostat but somehow was unable to properly reinstall the drainage...
Good day,
There is a drain cup in the rear top center of the fridge compartment that drains the water to the outside of the machine, down a drain pipe into the drain pan.
Hard to see the cup unless you use a hand mirror.
Dirt, can plug this cup and as well the hose and fittings in the back of the machine.
Removing this cup requires removing the front cover, and between cleaning it, the connection between the inside and outside of the machine and the drain hose can be tedious.
Don't force the situation. Shut the machine down, until it is completely defrosted.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
3,878 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
