Question about ECM Giotto Espresso Machine
Have a bad control board need to know where to get parts looking for part #c199901137
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Color going out on tv, model(ltv37 w 2hd
First try reseating both ends of the LVDS cable.
By "reseating" that basically means unplugging, and re-plugging them in their slots right?
fixed a few monitors similar to that by replacing a few bad caps. Look for swollen caps. Sometimes the tops of them will have a bulge or a split. It might be better to just replace them all.
Look on the Power supply board for Bad Capacitors they will be vented or puffed up on Top.
This board will be on the Far Left hand side,pull it out and look for bad Caps.
You need to know how to Solder. unsolder bad caps and replace with new .
Make sure you put them back in the exact same way the came out,they will be marked positive side and Negative - Side. If they are 1,000uf 16v make sure the cap is 1,000uf. If you want to just replace the board, here are some company's for Parts Encompass Parts Distribution 1-800-638-3328 Visit their Website they will list Parts /Prices they also have Free Service Manual that you can printed out. Parts 1-800-627-4368 PTS 1-800-844-7871 this company you can ship your boards to and have them repaired. Let me know if you need any more help.
Jun 15, 2011 | Televison & Video
Hooked new clock control panel wb27k5140 to ge profile oven jsp38g0s3bg, clock comes on but controls dont work
The description you have provided looks like it going to be a thermal limit switch that is bad (some of them are resettable). You need to remove the control board display. Once behind there you will see 2 limit switches. Try to test both of them with an ohms meter. Both should read infinite but I am sure one is bad. Here is a link to a schematic that may help you find the limits. The part numbers you are looking for is 158 and 159. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216517&diagram_id=21205724#d21205724.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 13, 2010 | Kitchen Ranges
Ice maker not working properly & Ice cycles in freezer
THIS IS WHY PEOPLE USE THIS SITE.ORDINARY PEOPLE NEED FRIENDS TO HELPOUT....
find an elderly person in your area that needs help, not charity.the feeling is priceless...
Feb 11, 2010 | Freezers
Refrigerator and frezzer stop working.GE model GTS22ICMARWW. UNplugged and plugged back in started working again have to do this about once a week
Because your model has a mother control board and you say that unplugging for a while helps I am focused on that board. It is pretty good sign that a relay or part of the circuits on that board are most likely the cause of the problem. If you could unplug the refrigerator and remove the panel located on the back of the refrigerator lets have a look at both sides for signs of heat, burn marks or melted solder connections. The part number for the board is
WR55X10656
and I have a photo of a new board and a photo of what to look for on one that is defective. This is the front of a good board.
Here is what to look for on both sides of the board. I need you to check that board first and you can let me know what you find. Or if you need the board I can help you find one at several sites. You can click on the part number WR55X10656 above or enter in the parts and model number search feature below and enter the part number and then click FIND IT. Or let me know and I will try to get one priced differently. We are not sure its the board yet so lets have a look at it and let me know what you find and then we can go from there, Let me know if this is helpful or what other things that may be happening like a fan motor may be going bad and stopping causing the compressor to overheat and stopping everything. Tell me if the lights stay on when the refrigerator stops working. Here are my sites below, Thanks, Sea breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Either way I will help you find the problem. WR55X10656
Aug 07, 2009 | GE Refrigerators
Fridge model#MBR2255kes. The freezer works fine,
Your refrigerator has a control board located inside the fresh food compartment. It is hidden behind the temperature control panel. This board could be your problem. Your fridge also has air dampers that are controlled electrically. We will still need to check the defrost element behind the freezer wall. Most times when this happens the problem is related to a control board or defrost timer. If you want to check these things yourself unplug the refrigerator and look inside the control panel to see if your board has burn on back and front. If you don't find burns on board then we will open the back panel in freezer to see if the coils are frozen over. You are free to ask my help if you like I will be here. You also can go to site link below and enter the model or part number in search feature. Let me know what you find, Thanks, Sea Breeze
Click link here V__V__V
Enter model first then it will take you to pictures of your model. On left side of screen choose photo # 3. When you click on photo 3 the part is # 5 in the photo. The part I think is the problem is part #
12868513
Let me know what you find, Thanks Sea Breeze
May 17, 2009 | Refrigerators
Kenmore front load washer wont spin...
check the motor control board ,,, sound like thats what your looking at
Dec 08, 2008 | Washing Machines
Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Nov 15, 2008 | BenQ DV3750 Television
Shorted control board dispenser
Look and see if the door for the ice chute is closing all the way. This model is bad about that door breaking. If it doesn't shut properly then warm air getting in will cause this condensation. Will also cause ice in bucket to melt and water can leak onto these parts. If it isn't obviously hanging open then shine a flash light from the inside down the chute and see if any light comes thru to the outside. Maytag has a chute door kit that you can find on appliancepartspros.com. Their part # is AP3140440. Let me know if this helps or we need to go further.
Oct 09, 2007 | Refrigerators
ECM Giotto Espresso Machine Logo
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
