Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
My Bluetooth V2.0 with not pair or scan intp my ps3
    Guru:
  • 395 Answers
PS3 supports Bluetooth V2.0, in fact the Playstation branded headset is V2.1. All versions of Bluetooth are backwards compatible. Are you sure that the headset is going into proper pairing mode?
See these tips:
Pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Pairing to PS3:
http://www.fixya.com/support/r5009279-pairing_headset_playstation_3_ps3
Posted on Jun 03, 2010
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
How do you get the ps3 to pick up the blue tooth head set
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
PS3 bluetooth headset won't work
hello,
ive had the exact same problem
make sure that the blue tooth is in "pairing mode" when the system is scanning.
reference to the bluetooth manual to put the device in pairing mode.
I hope i have helped and I hope it works
Jan 14, 2010 | Sony Playstation 3 (PS3) Console
I cannot get my Orb bluetooth headset to work. and yes before you say it im not a dohnut i did follow the instructions as they are put out but when scanning for bluetooth devices on my ps3 it scans...
i figured it out!!! you have to do the Scanning firstly then when you are asked to hold down the P button for 5 seconds and it turns RED immediately open the microphone whilst it is still RED and it will work (hopefully) then it will be registered with your ps3! (hopefully)
Good luck :)
Nov 18, 2009 | Video Game Consoles & Games
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
How to pair the bluetooth headset to the ps3
This is the info i got when i was looking to pair my headset with my PS3.
1. Turn your bluetooth headset on. It should flash on/off every few seconds.
2. Go to Settings > Accessory settings > Manage bluetooth devices.
3. Put the headset in "pairing mode".
4. Start to scan for the device. PS3 should pick it up. It will display the model if successful.
5. Once it's found it hit the options button. Connect the device (pairing mode) A blue icon will pop up.
6. Your headset will stop flashing meaning it has connected successfully.
7. Go back out and click on the audio device settings.
8. Input device > select "your headset". > output device > "your headset".
9. Hit the "connect bluetooth" icon. Then OK.
10. Your headset should now be successfully connected.. start talking into it to see the bar level move up and down to confirm its working.
Hope it helps.
Best Wishes,
Karlos
Jun 28, 2009 | Radio Communications
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Linking a BT125 Bluetooth to my PS3
I had the same problem trying to connect my old Jabra BT125 headset to my brothers PS3, here's what worked for me:
-Turn on the headset by holding down the button but keeping it down until a solid light comes on.
This puts the headset into discovery mode, you can the start scanning for the device and it should find it.
Jan 26, 2008 | Jabra BT125 Headset
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
170 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
