Question about Sony PSP (Piano Black)
My PSP does'nt turn on. I have bought a new charger and battery for my PSP. When i plugged in the new charger the orange charging light indicating it was charging came on. I tried turning on the psp and just letting it charge but no nothing happend. The light soon started blinking and went out. Any suggestions/answers?
  • 2 more comments
  • losthope_723 May 06, 2010
    No response after holding the R and turning on the power switch.No light, no graphics. I guess it must be bricked then... (-.-). Where do i get this pandoras program/battery/whatever else it is?
    My PSP will not turn on or anything. I first bought a new battery.... nothing happend. then I bought a new charger. When i plugged in the enw charger the orange charging light came on for a bit. I then tried turning on the PSP and nothing happend, no sounds or graphics. Soon after, the orange light started blinking and went out and no indications of a working PSP showed. One person suggested hoding the R and turning on the PSP but no luck. Suggestions/comments/answers?
    Ill have to look it up when im not on a GOC. Thanks though. I hope it works.
    ive got full motion of the power switch, have revarified my cables and connections, and have not tried anything with the firmware or whatever it is (@.@). Taking the battery out to try the "waking up a sleepy PSP" method did not work. No lights, sounds or graphics show up with the battery in or out while the PSP is on the charger.
    President:
  • 2,923 Answers
When did the problem started? Did you install anything or update the software? Or it was stocked for a long time?
If it was stocked, then the first thing that you may want to try is to use different battery and see if you'll get the same problem.
If same problem occur, though you've got new charger and tried different battery, then the problem has something to do with the small components around the internal power unit.
However, if your PSP won't turn on because of a program or software that was installed recently, you may need to unbrick your PSP.
You may check the link below for more info:
www.console-crazy.com
If that did not help, I would suggest to contact Sony, and have them check it, and see if there's any hardware defect.
Thank you and good luck!
Posted on May 07, 2010
  • 2,335 Answers
When PSP's are working properly, you are right the orange light should be on.
A blinking light (green) and then turning off is normal when it goes into sleep mode rather than full power down. However, even when it if off, it ought to show orange while plugged in.
I have seen troublesome PSP's where the switch was just failing; are you certain you are getting full movement all the way to the top when trying to turn it on.
Even with the battery out, it should boot up when plugged into mains power. have you given the connections at the power supply from the wall and into the PSP a good press and wiggle?
Also, removing the battery for several minutes and then plugging the battery and the power cable back in has been known to wake up a sleepy psp. The clock and settings will need to be setup again this way.
Lastly, if you have tried altering your PSP's firmware and failed at it, then the symptoms are the same. Your PSP is bricked and you will need a pandoras battery to fix it. (These are pretty easy to come by.)
I hope that helps.
Posted on May 06, 2010
  • Paul Sager
    Paul Sager May 08, 2010
    Your psp is bricked.
    You need new firmware.
    If it is older than a 3001 this is easy with a pandoras battery.
    Good luck & thank you for choosing Fixya.
  • 1,284 Answers
Hi, turn off your PSP, Press and hold the R button, and power on at the same time. This may reset the PSP. If not, do you get any sound? Look at the Display real close and see if you are getting any graphics. If your getting sound, and you can see some graphics, you have a back light problem. If you get no sound and cannot see graphic, then their is a high chance of your PSP being bricked. This means that you done something to interrupt an upload or program in progress. The eeprom program is corrupted and the PSP will not boot up. The term Bricked, refers to your PSP being no better than a black Brick paper weight. I have heard of a repair for this called Pandoras Battery.
You need to:- re-install your custom firmware. (Pandora's battery and all that) Then make sure your memory stick is a pandoras one and start again
Take care
  • 2 more comments
  • Shehu Pro
    Shehu Pro May 06, 2010
    Hi, you can learn how to do this by following the video on this link..
    http://www.youtube.com/watch?v=2HQOab5b3...
    Take care
  • Shehu Pro
    O.k, please don forget to accept and rate the solution..
  • Shehu Pro
    Hi, if this solution did not work, then i think it's high time you contact Sony...
  • Shehu Pro
    Shehu Pro May 07, 2010
    Any progress so far?
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
I have my psp plugged in to the power cord for over a day, still not charged and it wont turn on at all. why ?? please help!!!
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Jul 13, 2010 | Sony PlayStation Portable (PSP) Console
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Bought new charger and battery psp works fine but wont charge
It sounds like the PSP does not recognize the charger. I recommend buying a Sony certified charger.
Jul 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont turn on... i dont even know if its charging...i dont know anything about the psp. my psp didnt come with instuctions!HELP!!!
the way 2 know if tis charging is wen u plug in ur charger 2 ur psp on da right a orange light should appear and stay ther eas long as its charging . wen it goes away it should be blank. if this doesnt happen on urs i dont know why. it should have come wiv a anual in ur psp box unless u have bought a used 1 from someone in dat case dey mite have not given 2 u for whatever reason. i hope dis helped=)
Jan 14, 2009 | Sony PlayStation Portable (PSP) Console
Ok i just bought a new psp slim battery and a new charger and my psp wont charge and i dont know what to do but, i do have a psp slim 2001 (ice silver) and i bought a psp charger and battery thats 2000 so...
this is easy i solved it! buy a charger from gamestop that you have to take the battery out and then put it in the charger and charge it that way! that way if your fuse inside your psp is out it will charge the battey without putting it in the psp so all you do with the item is: take your battery out, put it in the alternative charger from gamestop (does not come with psp slim 2001 or 2000) plug the charger in the while charge the battery then bam!! there you go problem solved have a fun time playing your psp!
Apr 12, 2008 | Video Game Consoles & Games
Brand new psp battery will not charge
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
79 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
