Question about Sirius Satellite Radio sp-tk2 Satellite Radio Receiver with Car Kit
Engine noise through sirius
Hi, just put my sportster in to a different truck, I am having trouble with it now. Getting engine noise through speakers when sirius is plugged in through aux cable to stereo. I play my mp3 through the same cable and no noise. If I play the sirius through the fm transmitter it is also fine. Have tried getting power from another plug in the truck and get same result. Help please.
  • 86 Answers
First check fo good ground on lighter socket sometimes manufacture's use whats called a floating ground which is one wire connecting every socket for a ground . This creates what is called a ground loop and can create noise. Instead of rewiring try an inline noise filter. check with your local car audio store. Hope this helps. If not write back.
Posted on May 06, 2010
Can my sirius sportster 2 won't receive channel 210
Yep, new radio. The old Sirius radios won't go above 184 (most won't even get above 145) and the old XM radios won't go past 256, so to get the "Xtra" channels you want a new XM radio like the Onyx PLUS, or The XM Edge - both will give you not only all the regular channels, but an eXtra 20 channels or so that you can only get online or on a new 2.0 radio. Let me know how it works out for you. Regards, Engineer Scott
Jun 06, 2014 | Clarion (NAVSIR) SIRIUS Radio Receiver
Sportster 5 turns on and off randomly every few seconds hooked to a dock.
Sportster units get very hot ! If you use it in the boombox stop ! Take the radio unit out - remove the silver cover from the boombox ( don't overlook the 2 hidden screws under the speaker grills ) take a dremel tool with a cutting wheel - and cut all the shrouding away around the top of the reciever. This will allow the radio to run way cooler ! I also drilled several holes thru the swivel mount to allow better air-flow !
Jan 02, 2012 | Sirius Satellite Radio Sirius Sportster...
I have my satellite radio installed in my car and I am getting a whining noise which get worse with higher rpms. What is causing this and what can I do to fix it?
Alternator noise. Use all shielded audio cables. You can also add 'ferrite rings' to the audio calbe and to the power connecotr cable
Aug 26, 2010 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Acquiring signal
My wife replaced the car kit.
The sportster itself was fine, what fixed the problem was replacing the cradle.
Now the second one has taken a dump.
May 21, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sportster 4
Dick,
Did u go to the menu to get the Sirius ID# or ESN# or did u get it from the box or back of the unit itself?? I used to work in activations department for sirius and the most common reason that a plug and play unit would not activate is a mismatch in ID #'s. I have seen units with one ID number, but the box or the back of the radio actually being labeled with a different number. By the way,only one signal can be sent to the radio every 20 minutes or so and most reps you talk to don't even know this. So after sending the first signal, all they are doing is clicking a button on the screen and getting a message back that says "Duplicate Provision" meaning that the signal cannot be sent because it is already sent. If you were hearing audio on channel 184 when the signal was sent and you made no adjustments during this time, and the SID or ESN number is the correct one for your unit, and the radio doesn't activate, I would get a replacement. But this never happens in my experience unless there are other signs of defect.
Hope this helps!!
Feb 29, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
Feb 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius Sportster 4 Problem
sell it or so many of the units run into this problem and nobody knows how to fix it.
Sep 25, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Sirius Satellite Radio sp-tk2 Satellite Radio Receiver with Car Kit Logo
338 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tom Chichester
Justaguy
Level 1 Expert
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
