Question about Marantz Audio Players & Recorders
Marantz 2330B sinto amplifier:no sound ,seems to be with trouble in the sound circuit ,none of the external outlets
5 Suggested Answers
pra0099
  • 153 Answers
SOURCE: Used banana plugs for my amplifier, but bare ends
If you were playing with the speaker out ----off sure the amp IC is blown or the related circute problem as occured
if you smell the shot circute ...tipically a silicon burn smell....then ...there is a problem in side....
remove the cover and physical check for the blown parts using a tourch if you fing any parts or the bord blackning.........
fault may be there\
some times with a small blown fuse replasement ...cure's it .........
Posted on Sep 20, 2009
  • 4 Answers
SOURCE: sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
Posted on Mar 02, 2010
petraman7
  • 1175 Answers
SOURCE: marantz amplifier pn 50
www.stereomanuals.com
Posted on Apr 14, 2010
petraman7
  • 1175 Answers
SOURCE: Need the circuit for the input to Marantz 1050 amplifier
Check with a website call hifiengine
Should be there
Posted on Aug 19, 2010
No sound everything is on but tape deck does not register when depressed any suggestion?
Tape decks have separate pre-amp circuit. These days one IC will do most of the work. If it goes the sound will vanish.
Oct 15, 2015 | Marantz Audio Players & Recorders
The sound is gone
it will depend if the problem is only the speaker of the tv itself is bad, you can hooked up external to the headphone jack.but if the problem is with in the amplifier circuit you must trouble shot the circuit first.might the amplifier ic get bad.
Oct 10, 2012 | Televison & Video
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Mar 08, 2011 | Marantz SR-5000
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
Marantz amp will not put out any sound
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
Feb 16, 2009 | Marantz Audio Players & Recorders
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Oct 02, 2008 | Marantz SR-7200 Receiver
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
199 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
