Our brand new, not even used yet - just tried to run a normal cycle to clean it out before using it for the first time, 3000 series front loading Maytag washer is leaking water from the front bottom portion of the washer. The water is not coming from around the door seal. We have the washer on a pedestal. Any ideas?
SOURCE: My brand new Maytag 3000 Series frontload washer
My washer is only a year old and it is so load and it sounds like there is something in the mashine banging.
SOURCE: Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
SOURCE: I have a brand new Maytag 3000 washer and it keeps
check to see first if you have water comeing out of both hot and cold hoses. are they turned on? take the hoses off the washer and get a bucket and turn one hose on at a time 1st the hot then the cold what happens?
SOURCE: MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
