Question about Craftsman Push Rear Bag Lawn Mower w High Wheel (CA)
Can't seem to get my mower to keep running
Here is what I have done this far. new Spark plug, new air filter. I want to change the fuel filter but not sure where it is on my mower. a Craftsman 4.5 eager-1 21"
  • Ohiolndscper May 11, 2010
    There typically is no fuel filter on that small of an engine. If your Craftsman walk behind has a 4.75 HP or similar-sized Briggs & Stratton engine, a small piece of crud may have inadvertantly gotten stuck in its carburetor. How? Often, air cleaner assys are not tightened down enough, or the foam air cleaner element is not in place, has never been cleaned, or is missing altogether. You can try 'Gumout' & try to flush it out. But in many instances, the carb needs to come completely off in order to find it. These carbs are not tough at all to remove. Just drain the gas tank & remove it carefully. Look carefully at all linkage points & make careful notes as to where they hook up, before you remove the springs. Then back out all bolts securing carburetor.
  • Ed Gore May 11, 2010
    a lot of the filters are inside the fuel tank. Connected to the pick up tube. Most smaller mowers do not have inline filters anymore.
  • 198 Answers
The problem is probably the carb---take it apart and soak the parts in some solvent. make sure the float valve moves very freely.
Posted on May 07, 2010
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
18.5 briggs intek vtwin only runs choke on only
Make sure the fuel jet is clean. Its easy to miss when cleaning the carb. Ive seen a lot of dirty fuel jets that once I clean them out run like new after.
Sep 25, 2014 | Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Yard machine riding lawn mower
The dead-man switch on the lever (that you have to hold in to keep it running) has a loose connection or you have a loose spark plug wire.
Aug 18, 2014 | Yard Machines Garden
Mower cutting out
be sure vent is clean in gas cap
Sep 25, 2013 | Garden
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
My lawn mower starts, then stalls immediately.
the carb will need to be removed and cleaned and blown out or ultrasonic cleaned is best if you can get that done? if not a can of carb or brake cleaner and blow through all the jets the blow out with compressed air
Jul 08, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Push Rear Bag Lawn Mower w High Wheel (CA) Logo
493 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
