Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson Stylus CX3500 OS Windows 7
Installed above mentioned printer but my scanner does not respond. When I open Smart Panel "Scan and Save" application not responding.
What can I do?
jacklee366
  • 541 Answers
SOURCE: Epson Stylus Photo 890 doesn't respond
your printer needs to be reset the software is called the scc put that in google and you will see it
Posted on Nov 23, 2008
Ajkill
  • 2035 Answers
SOURCE: Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 26, 2008
  • 18 Answers
SOURCE: Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
Posted on Jul 07, 2009
pidatoo
  • 118 Answers
SOURCE: i can t find a driver epson stylus photo 950 for mac os x 10.4.11
find the manurfactures website they usualy have the DRIVERS to install for free on their site, from there you can download it.
Posted on Jul 23, 2009
seanpwright
  • 2030 Answers
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Posted on Aug 27, 2009
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
I have upgraded my system Os from XP SP3 to Windows 7, after that when I installed Epson Stylus CX2800, everything was working fine except Scan program
Get a windows 7 driver for the printer or an update from epson, un-install the old one then reinstall the upgraded software.It did the same with my Lexmark,but I did get the newer driver from Lexmark and it worked out fine.
Dec 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
Epson Stylus Photo RX500.
hi there.. seems, a hard job huh? transfering it from 1 folder to other.
try this , open epson scan program, goto home mode. click preview, click scan, it will open file save settings window where you can select where to save your picture, under location , look for the folder where you want to save it, if its not on the list, select other then look for the folder or for your appleworks, once you found it, click ok, it will scan and save directly to the appleworks.
i hope this one works for your.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 06, 2010 | Epson Stylus RX500 All-In-One InkJet...
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
My epson cx3500 printer does print but is a bit faint. I have forgotten how to clean it. All the ink catridges are full.
If you ar in windows xp open control panel then click printers and faxes, right click the icon for your printer then click printing preferences, go to maintenance and there you are, just click head cleaning. it's better to do the cleaning 3 consecutive times if your printer was idle for a long period. Good luck!
Jan 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
CX3500 properties not found on my laptop
Hi!
You cant download properties, but you can download the scanner drivers:
http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=styluscx3500&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2852087&sCategory1=Multi_Functional
On that site you will find anything you want, just select your OS first.
Good luck
Nic
Apr 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus PHOTO RX425
Epson has software called "Epson smart panel" and you can select scan from the list of operations.
Turn your scanner on, (windows OS) click on "start" then click on "all programs", look for epson smart panel in programs list, click and let panel load, then select scan.
It will take some time for the scanner to warm and scan, so be patient, after it is scanned your options are to print, or save. If you save, be sure you know where its filed or "tell" it where to save, I recommend creating a new folder before in "your pictures" titled "scans" . Usually after you do this, it will save it there by default.
Dec 09, 2007 | Epson Stylus RX425 Multifunction...
Can't get it to scan
1. Make sure the shipping lock on the scanner is free see- set up sheet. 2. Remove all Epson software relating to this device. 3. ReBoot. 4. make sure you are off line. 5. Fully disable any Anti Virus software Switch off the unit and disconnect the USB cord 7. Now install the software and follow the EPSON steps exactly -take no shortcuts
Jun 08, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
320 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
