Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Will not start. Replaced battery thinking it was
Will not start. Replaced battery thinking it was bad as it would not jump. Fuse is good. Doesn't even want to turn over almost like the starter is locked.
    Sniper:
  • 53 Answers
Make sure all connections are CLEAN first. Especially if your battery wire has a plug and socket connect at some point. To test the starter make sure you can tell which leads are which ( - Black = negative or + Red = positive) Don't guess or assume. MAKE SURE. Then you can test the tractor starter with your car battery and a pair of jumper cables. But (Und this is a big but!) Make sure the tractor battery is 12Volts and not 6 volts!If it is 6 volt you can't test it with your car battery.
Posted on May 06, 2010
Had to jump start bike head light tail light and nutruel light not working fuse ok what now?
Hi Randall:
Since you had to jump start it I;ll assume that the battery was dead.
Have you charged the battery or replaced it?
If not, try to charge it using a battery charger. If it won't hold a charge, replace it.
Odds are that you'll have solved the problems.
Jul 07, 2015 | 2001 Honda VT 1100 C2 Shadow Sabre
97 geo, wont start
if it doesn't crank over test the starter jump the small wire on the starter to battery voltage if it cranks there the problem is the car side if it still doesn't crank the starter is bad
Aug 18, 2012 | Cars & Trucks
91geo prism had a dead battery,jump started it And the battery light stayed on, so I put a new battery in and will not start but spins over great. Found the 30 amp fuse bad on the positive cable and...
You will need to check all the fuses, the main and inside fuse box. for the amp fuse to blow the jumper cables or battery were installed backwards. check all fuses i think you will find another bad one. as far as the batttery light being on, you may have a bad alternator. the car will run until it drains the new battery. the battery light may still be on once you get car started. have the charging system checked.
Again i think its just a bad fuse, the car was starting fine until the battery replacement.
The last thing is that sometimes they loose the idle memory or get flooded from connecting battery with key on, try to start by controlling the gas. hold gas pedal to floor and try to start engine. asengine starts slowly release gas. if car stalls out when gas pedal is let go then restart and hold gas pedal a little for about 2min then release and let idle, good day.
Feb 22, 2012 | 1991 Geo Prizm
Whole fuel system
The main fuel pump in a Volvo is really well built and rarely fails (Bosch simply makes great fuel pumps). A good survival trick if you think a main fuel pump might be bad... give it a quick tap with a wrench. For best results, if possible, tap the pump when cranking the engine (while power is going to the pump). If the pump is bad, often the tap will make it come to life and it may stay running until you shut it off. This trick can get you back on the road and get you home in an emergency. If it's a bad fuel pump relay, this will NOT work as there will be no power going to your pump. If this is the case, you might try the below relay bypass "jump" trick to get power going to the pump. TESTING YOUR FUEL PUMP
How to "JUMP" the fuel pump circuit at your Volvo 240 fuse panel:The fastest method to make the main fuel pump run (bypassing the Fuel Pump Relay) is by jumping two circuits at the fuse panel (left side driver's kick panel).
You can make a jumper from a wire with stripped ends or even a straightened paperclip. Jump the circuits on the right side of the fuses for best results
For a 1979-84 240, jump fuse circuit #5 to #7.
For a 1985-93 240, jump fuse circuit #4 to #6.
If the main fuel pump doesn't begin running when jumped (you should definitely hear it humming), you either have a faulty fuel pump or faulty wiring to the pump (bad wiring is really common under an old 240, near the pump). This test of course assumes your battery is good.
If one of the fuses blows during this test, the pump circuit wiring is shorting to ground somewhere between the fuse panel and the pump.
thx
Jan 18, 2012 | 1984 Volvo 240 Series
No Electricity
Will it jump start?
if so bad battery, if not bad connection..
Sep 13, 2009 | 1999 Honda Accord
1991 Camry, ran battery down, won't start with jump.
Check all fuses under dash and hood. Install a good battery or jump it. Have someone try to crank it while you check for voltage to the starter solenoid. Make sure all battery connection including ground to body are clean and tight. If good, make sure there is 12volts at the stater. If good, it sounds like a new sarter. Please let me know. Is this standard or automatic?
Jun 08, 2009 | 1991 Toyota Camry
Mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
