Question about Aqua Pool & Spa
My pump blew a fuse which i replaced but still have no power , nothing works
  • 198 Answers
Try checking for a re-set button on the motor housing----it works like a circuit breaker.
Posted on May 07, 2010
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
Went to change thermostat on heat pump from conventional to digital. Did not shut power off. Could not get digital to work. Nothing, no heat, no air conditioning, and no fan. Put old thermostat back on,...
Here are the things our company would check 1st: Check to see if you have a control voltage fuse in the air handle section. If it is blown replace it and try again. If it blows again you may have wired the thermostat incorrectly. If there is no fuse than yes, you may have burnt out the transformer. Hope I helped.
Nov 08, 2013 | Ruud UBHC Air Conditioner
Why does my fuse for fuel pump keep blowing on 1992 ford ranger even after i replaced relay thinking that was the part needed?
the power wire to your relay or pump is very weak or grounding take a reading with an ohm meter continuity one lead from fuse other on ground
Mar 26, 2012 | 1992 Ford Ranger
CHANGED WATER PUMP NOW THE TRUCK DON'T WANT TO TURN OVER?
Did you disconnect/reconnect battery? Do you have power? Are all the drive belts properly routed and tightened? Is coolant/water levels full? How bad did the truck overheat before you changed the water pump? If the truck was running fine before you changed the water pump, then double check that you properly reinstalled and reconnected all components you removed to gain access to the pump. Make sure your battery connections are secure and properly charged. If you didn't disconnect the battery when replacing pump, it's a possibility at some point you could have shorted the battery to ground and blew a fuse. Check all of your main fuses, then check all other fuses.
Otherwise, even if you installed a bad water pump, it has nothing to do with truck turning over. The only possibilities are that engine froze before changing pump, drive belts not properly reinstalled/secured, components not properly reinstalled or connected, or battery shorted and blew a fuse, or fuses. Let me know how it goes.
Jun 14, 2010 | 1998 Nissan Pathfinder
Fisher Paykel Washer (GWL10) is not powering up
yes motor controller module blew, check pump windings for and discolouation before fitting new module the pump can blow you module,
PS always switch off at wall when not in use
Sep 09, 2017 | Washing Machines
PT-52lcx65, lamp blew, replaced lamp and ballast...nothing
If you don't get a LED power indicator I would suspect the power supply. Could be as simple as a blown fuse..
Apr 02, 2009 | Panasonic PT-52LCX65 44" HDTV
2000 GMC 2500 Fuel Pump?
check for power too the pump first with a test light if you have power too it then the pump is bad if not youve got a short some gms also have a fuse check for that also
Feb 23, 2009 | 1985 Chevrolet Chevy
Indesit WG1235T O
I would say the doorlock switch is faulty
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Pool & Spa Logo
80 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
