Question about HP Photosmart 3210 All-In-One InkJet Printer
Paper jam we can't clear a paper jam
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 53 Answers
Disconnect the USB cable from the back of the printer.
Now, First of all make sure there is no paper pieces stuck inside the printer. To take out the papers.
Take out the duplex-er ( A box at the back of the printer which has two buttons at the ends of it which you can press to detach it from the printer :- It is used for duplex printing ) from the back of the printer.
Once you take it out you can see the ROLLERS and the ROD which takes the printer page and rolls back to give you the out put.
If you see any papers stuck inside then take it out. Now
Take a lint free cloth and clean the rod and rollers. Try to move the rollers in clock wise or anti clock wise direction. If it moves fine Other wise hardware issue.
Now attach the Duplex-er back to the printer.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the paper jam option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
Posted on May 06, 2010
Remove paper jam
you MUST get the tiny paper out of the machine. It will make more jams for sure. If you do not have a manual or someone handy try looking up your printer model on the web for jam clearing advice at the location where the paper ripped. Usually there are numbers. Sorry!
Feb 20, 2015 | Office Equipment & Supplies
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
HP Photosmart 3210 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
