Question about Olympus E-1 Digital Camera
Card error I have a e-1. Two memory cards with 1 and 2 gb. I get a "card error" message when I insert either into the camera. I brought it to one camera shop. They said that a couple of the pins (that connect the memory card to the brains of the camera) were bent. Recently took it to another repair shop and he inserted a card with less memory and the camera worked. Is it the cards or the camera? Will the camera work (with bent pins or whatever) if I get a new memory card?
  • 2,517 Answers
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Posted on May 06, 2010
My Panasonic DMC-FZ20 says Memory Card Error.
Hi
Please check your cameras capability to support larger sized SD cards.It may not support those two SD cards.Also check for slide locks on the side of the cards and slide them to 'open' before inserting.
Hope it helps.Thanks!
Feb 18, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
It says memory card error.i took out the sd card and it was not locked and it still says memory card locked. i formated the card also and it still says the same thing.
How big is its capacity ? Some device can only support memory card at certain maximum capacity, if you inserted card with higher capacity it wouldn't able to read it and it would say "card error".
Try to insert another card with lower capacity. i.e. if you have got "card error" notification for inserting 4 Gb memory card, try to insert 2 Gb card
Hope this help, and if you think its helpful RATE please.
Jan 28, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Memory card error
This seems to be a known issue with the Canon camera's to display Memory card error.
Give this a try
1. Remove the card from camera and wait for sometime ( 1-2 minute ) and re-inserting the card.
2. If this does not work, you need a card reader to read/view images on your PC ( since you are not able to access the card in your camera )
3. If you are not able to access/view the images from Card, click on the link below to recover the images from card - Recover images
When you open the webpage, click on the Download Now option to download the software ( it is free )
4. Try this fix to resolve the issue, Sometimes it takes long time for the camera to load the images and it results in memory card error - Click on the link to download the fix - Firmware Update
5. Try using a SD card with less memory like 1 GB card or max 2 GB for better access of card in camera.
Hope this is helpful.
Nov 05, 2010 | Canon PowerShot S3 IS Digital Camera
Cha flashing when new memory card inserted... have tried several to no avail... please can you help?
CH A error indicates that the camera can not communicate with the memory card. Most often this is caused by formatting a memory card in a computer and then putting it into the camera. (Especially on 4 + gb cards). Solution is 1. Reset the camera - then it should work with cards that it worked with in the past. 2. Take the bad memory card and reformat it in your computer to FAT not FAT 32.
It should now work - although it will show capacity to be only 2 gb...
I believe at that point, if you reformat it in camera it will work at the full 4 gb.
Oct 22, 2009 | Nikon D2X Digital Camera
2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Jun 03, 2009 | Kodak EasyShare C330 Digital Camera
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
Card error message during formatting XD picture card
The max card size for the camera is either M or H512mb. Try the following website to locate cards for sale www.oempcworld.com
Nov 11, 2008 | Olympus Camedia C-350 Digital Camera
Sd elite pro 2gb
What is the error message you are getting?
Have you formatted the memory card?
Jun 09, 2008 | Canon MV730i Mini DV Digital Camcorder
Olympus E-1 Digital Camera Logo
234 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
