Question about Echo CS600P Gas Chainsaw 20 Inch
No Start Echo CS 670
Have 2006 Echo CS670 purchased new. Light to moderate use around house/yard. This year(spring) cut 1 dead tree and saw stopped running and starter was impossible to pull. Took it apart saw nothing but was ablle to get the engine to tturn by tapping fly wheel. Started and cut two stumps plopped and went dead like out of gas bu was not. Has fuel and fire at plug and in cylinder but will not start. Echo Dealer(Local Ace) completed diagnosis and determine engine is junk, low/bad compression (but it doesn't feel like it).
It's outside warrany period. Fix/rebuild is $400+.
CAN'T BELIEVE A LOW HRS of USE AND HIGH DOLLAR SAW IS TOAST. IT HAS NOT BEEN USED HARD. Any ideas? Hate to trash it if reasonable fix avail.
    President:
  • 2,220 Answers
Sorry to echo the bad news you heard but... often metal transfer from the piston to the cylinder feels like compression. Try part 3 of this, Attempt to shine a light into the plug hole through while inspecting above the exhaust port. Most often in a run lean condition metal transfer occurs above the exhaust manifold.
Starter Handle difficult to pull:
1. Remove the starter cover.
Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair or ordering any parts; if yes continue.
Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
Leave the ignition off, set the valve and pull the starter.
Pull gently to release the valve. Is there a difference in the effort required?
If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
The cost of a P&C nears the cost of a new saw. Join here, search for acid and maybe you can get by with just replacing the piston. This is good bunch of folk that will offer all help possible.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
An example of a repair here:
http://www.arboristsite.com/showthread.php?t=135021&highlight=acid
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
  • dontbother10
    dontbother10 May 06, 2010
    Sometimes the tool rental center of a local Home Depot sells used Makita DCS6401 saws. They generally go for $200-300. This is a fine professional quality saw made by Dolmar. As long as you leave a deposit they should allow an inspection by an independent mechanic (I suggest Stihl $10-20). I would explore this possibility before investing in a run lean repair. It may be possible to recoup some of your Echo investment by selling it for parts.
I purchased a new saw yesterday.I would like to keep my old saw. Will it be wise to purchase a used crankcase with a complete short block..if so which is more compatible with the echo cs-400.thanks
It depends on how much you like to tinker around with small engines and how much money you're willing to put into a 'back up' saw.
With new saw prices nearing $700 - $800 for pro series saws its easy to justify repairing them if you're capable.
Apr 16, 2015 | Echo Garden
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
Cs 400, first time cutting great, then the saw did not cut perfectly. Recently it worked poorly. When I push the saw a little bit hard against the log, the saw did not running(the engine is working)
suggest you sharpen the chain, sounds like it's dull like maybe the log you cut had been fallen on ground for awhile, this causes dirt build up in bark and acts just like cutting Dirt and we all know what that does to your chain...dulls it fast ! I learned from experience I cut an oak tree that was cut down for about 2 years when I got permission to cut it up,needless to say it had a lot of dirt in the bark! hope this helps you !
May 15, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
A fellow firefighter was cutting with his Echo
The cylinder (if engine running too lean) would be badly scored as well as the piston and rings. Knowing today's prices for parts and labor, $300 is probably not too far off. At that price though, he might consider replacing the entire saw rather than repair. I have noticed a number of Echo saws that don't seem to 4-stroke when running at speed, but not cutting. A properly tuned 2-stroke should always 4-stroke at speed, but immediately 2-stroke when cutting--this produces the most power and least heat. The fuel should always be premixed in the can, agitated well during mixing and again before using in the saw. Agitate the saw after adding the new fuel as well. At 50:1 ratios, there isn't much spare lubrication in the engine. He might consider another brand of saw if buying new. Hope some of this helps!
May 10, 2010 | Garden
NEED TO FIND A NEW 14" CHAIN AND BAR FOR ECHO CS 305 SAW. NONE LISTED AT LOWES OR HOME DEPOT. THANKS FOR ANY INPUT.
What you are looking for is the following model bar:
Echo 14A4CD3752
If you cut and paste that into google or another search engine you will find numerous online retailers who can sell and ship you this bar for your CS-305 saw.
Apr 06, 2009 | Echo Garden
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS600P Gas Chainsaw 20 Inch Logo
793 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
