Question about Black & Decker String Trimmer Cordless 12" 18V
Black and decker nst 1810 model How do I replace the string?
How do I replace the line on my GRASSHOGG automatic line spool? How does the spool come off the model B&D 1810?
  • 3 Answers
SOURCE: changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Posted on Nov 19, 2007
  • 313 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
the problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: ENGINE WILL NOT ENGAGE WITH SPINNING SPOOL
I had the same problem, The pully is plastic and is mostlikely melted. I took mine apart when it finally stopped working and found that the belt had broken as well. When taking it apart, there is a hidden screw under the black sticker label. Just feel for the soft spot. Also, there are screws under the black plastic embelishments.
Posted on Jun 02, 2010
  • 3 Answers
SOURCE: My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Posted on Aug 14, 2010
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String won't advance automatically. Thank you so much for any assistance! It's a Black & Decker ST 7000 edger/trimmer.
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Apr 06, 2010 | Black & Decker St7000 13'' Automatic Feed...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Changing spool on weed trimmer
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
660 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
