Question about RCA D52W19 52" Rear Projection Television
I have a crosley projection tv. im not sure what
I have a crosley projection tv. i know i need a new bulb but im not sure what type of bulb it needs. im pretty sure its a 52 inch
texasdan
  • 60 Answers
SOURCE: 52 inch rca rear projection
I repaired an RCA 52" TV. I found two capacitors on the board that were bad. They were bulged on the top. This seems to be a common problem on many projection TV's. Try searching this website using the model number as your keyword.
Hope this helps,
Dan
Posted on Jul 24, 2008
Mr Alexx Sir
  • 12 Answers
SOURCE: TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Posted on Jul 29, 2008
  • 2920 Answers
SOURCE: Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Posted on Feb 04, 2009
  • 65 Answers
SOURCE: chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Posted on Apr 22, 2009
smarthome2
  • 1114 Answers
SOURCE: 52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
Posted on May 17, 2009
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
I have a 50 inch Philips Magnavox LCD TV. It worked fine till the power went out this morning. Everything came back on fine except for my TV. It still receives a signal but it has no picture and no...
The projection bulb came on,but didn't stay on mean the bulb have problems,dosen't mean projection bulb it still good.First must replace a new projection bulb to make sure for the elimation for the projection bulb is the problems.These DLP tvs require new projection bulb every 1 1/2 or 2 years by watching the tv like 4 or 5 hours daily.So there no lost there for trying a new projection bulb alway can save it for later use.The secound could be the board that call the Ballast board have problems too.The Ballast board only job it is to ignite to the projection bulb and make it work.Replace the Ballast board too,if the tv new projection bulb react the same way.
Mar 23, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The tv will not turn on. I need to change the bulb in the tv
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
May 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I need a new bulb for my tv model no. PT-52LCXX66-K and Im not sure how to look for one or where to find it...
Tries websites like partstore.com,Ebay.com to buy one.U know how to replaced the bulb?U can what a tutoring video on You Tube,just type ur tv model and make it will have it or it close to ur models.
Apr 14, 2010 | Panasonic PT-52LCX65 44" HDTV
No picture
This problem cannot be fixed without opening the TV Im assuming sound without a picture? check the inverter voltage on the powersupply for the bulb.Look for burns bulged caps.start from the the wires comming out of the bulb housing and work backwards untill your checking the wall socket.A big problem with older tv's is heat causing the board to crack try applying alittle pressure around the boards and see if it turns on.Check the bulbs but be careful with the age of this tv and the price of the bulbs you wouldnt want to buy it unless you know for sure.
Apr 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replacing a bulb in a mitsubishi rear projection tv
Are you sure tube is bad and that projecion fluild isnt contamiated if tube lights up but you can not see a picture clearily or at all fliuld is bad remove old fluid replace with new problem FIXED Call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Mitsubishi WT-42311 42" Rear Projection...
What bulb to get for my m50wh72s
Check this website to find a replacement lamp for your TV. You will need to use the housing from the defective lamp.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Only have a green colour for all tv and dvd pictures on Samsung Tantus Rear Projector TV (Model # SP-43J8PF). Is this the globes or is it stuffed?
ok hi there now inside a rear projection tv is 3 globes i big mirrior
and all the wires are under now it sounds like you do need to replace the globes but to be sure the others are ruined you can pull it apart take the screen off
so now u can see inside u will see three bulbs full of liquid
make sure none is leaking as they can
then turn on your tv (its all safe) put on a channel and look at the bulbs to see if one or any aint workin
if there are working turn tv off and get a lint free cloth or tissue and wipe the top of the bulbs do not turn them adjust them at all
need any more help im chris07551
Jul 18, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
