Question about Dryers
Dryer shuts down in the middle of the cycle before the timer goes off. if you try to restart it will not. wait 15 minutes or so and it starts right back up and finishes drying the load.
    Problem Solver:
  • 8 Answers
Probably the motor is getting too hot and the thermal overload switch is shutting it down.Usually means bad motor or dirty motor. You'll have to take it apart to see. Model # and Brand would help.
Posted on Mar 27, 2008
Ge dbxr463gd1ww stops before cycle ends
Sounds like a safety or limit switch cutting it out, if you wait 2 minutes and it restarts then repeats.
Aug 27, 2013 | GE Dryers
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
My kenmore electric clothes dryer model #110.86984110 shuts down in the middle of a cycle. After a while I can restart it and will run for a little while longer.
when was the last time you cleaned out the dryer,could have a blocked vent line,blocked blower wheel duct where the filter slides into and vac out the inside of dryer,go outside and make sure the air is blowing the flapper fully open,might have to blow the line out with a leaf blower,if the heat can't escape the dryer over heats and shuts down, could have a bad timer,thermostat, or you also could have a bad motor that would also heat up and shut down if it's bad, but try the clean out first and go from there,good luck
Dec 05, 2009 | Kenmore 64902 Electric Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
My dryer shuts off before it is done with the drying cycle there is still time on the timer by the dryer quits
1 all dryers have a cool down cycle from 15 minuts down
if this is not the case does it stop at the same place everytime
if it does you need a new timer
Oct 08, 2009 | Dryers
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
Sep 24, 2009 | Whirlpool LER7646E Dryer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Kenmore Dryer
yes it does sound like the timer itself. sometimes if the timer has a bad contact then the timer will loose power as it goes around. by turning the timer around 1 time it resets the contact and it starts up again.
Jun 28, 2008 | Dryers
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Dryers Logo
266 people viewed this question
Top Dryers Experts
