Question about HP Photosmart 3210 Printer
Inksystem failure - HP Photosmart 3210 Printer
    Scholar:
  • 62 Answers
Hi ,
please follow the steps metnitioned below:\
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved if not then you need to service the printer. all the best
Posted on May 06, 2010
Display reports: Problems in inksystem. Error no: 0xc18a0306 What do i do?
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
May 26, 2011 | HP Photosmart 3210 Printer
0xc19a0023
Inksystem failure?? Please reply to this post and tell me what is the model number of your printer, then I will provide the steps on how to resolve your issue.
Feb 17, 2011 | Office Equipment & Supplies
Printer says inksystem failure error code Oxc19a0035
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Nov 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error inksystem
An ink system error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Jul 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
My 6180 hp printer keeps saying inksystem failed and shuts off. what to do
This same error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers
Apr 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hi, will not clean, makes loud beeb when trying to
NEED TO CLEAN INKSYSTEM ASSEMBLY.......... OR YOU CAN CHANGE IT
Jan 08, 2010 | Epson Stylus Photo R200 InkJet Printer
HP inksystem failure - THANK YOU !!!! Whoever you are.
It has been a pleasure. Please rate our service by clicking on the thumbs-up icons. Thanks!
Aug 11, 2009 | HP Photosmart 3210 All-In-One InkJet...
Hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
Jun 17, 2008 | HP Photosmart 3210 Printer
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
