Question about Epson Stylus C86 InkJet Printer
Paper jam Released paper and pressed OK Printer still registers paper jam I have an Epson Stylus C86 - when I print, the paper will go down and seem to start printing and then it jams and I have to pull it out. As far as I can tell there is no paper jammed in there. It just won't go through smoothly.
  • Epson Master
  • 1,879 Answers
Your having a hardware issue and you need to have it serviced.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Posted on Mar 27, 2008
SOURCE:
Epson dx7400 printer jam
Turn off the printer and then open the scanner unit. Cancel the print job.
fon3_38.gif See Canceling Printing h018013h.gif step_2.gif Remove all of the paper inside, including any torn pieces. h018014h.gif step_3.gif Close the scanner unit and then turn on the printer. h018015h.gif
Aug 27, 2009 | Epson Stylus C86 InkJet Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Feb 05, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 won't print
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
http://www.ssclg.com/epsone.shtml
This program can show you if the waste pad is full, or what problem is happening.
Apr 07, 2008 | Epson Stylus C86 InkJet Printer
Problem after jam paper
Turn off printer
-check for specks of paper inside the printer or parts that may appear to be damage.
-turn printer on
If you'll get the same error lights chances are there is an internal error. Sensor mechanism might be damage.
Check this site: www.epson.com/loyalty and use the passcode: Lock then register.
Thanks for your time, hope this will help.
Apr 05, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 streaky printing
I'm not sure what to tell you. But for solutions try epson.com/support or call the support center at 562-276-1300. They've been very helpful and patient with me.
Apr 02, 2008 | Epson Stylus C86 InkJet Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
