Question about Spark Plugs BR4HS Plug 10/BX #3322
What is the correct sparkplug gap for a 1973 85 HP Johnson outboard?
  • 905 Answers
.030" per the listing here and here
Posted on Jun 12, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Please - spark gap for 4 HP twin two stroke johnson outboard
.025"
you should be using multi discharge point plugs in out board motors -not regular car engine plugs and the gap is preset on them
the reason being , with multi point discharge they are less likely to foul from oil and carbon build up
available from any good auto parts shop or marine shop
Feb 13, 2017 | Johnson Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Has compression and fire but dont start
Remove sparkplugs and squirt some fuel in cylinders. Replace sparkplugs and start motor. If it fires up you have a fuel problem and a good carb cleaning should clear the problem.
Mar 16, 2014 | Light Outboard Motor Boat Bass Fishing...
Need to know how to set the timing on my 2000 90hp omc johnson outboard and where to can i find a free online repair manul
Special Tools Are Required To Set The Timing On a 90 Hp Evinrude.
However You Can Check The Timing With a Timing Light.
This Engine Has Optical Timing Sensors And Bright Light Can Effect The Timing So Avoid Shinning The Light At The Sensors!
The Correct Plugs Must Be Used With This Engine Or Miss Fire Will Occur
Correct Plug Is QL82YC Champion 0.8 mm Gap
Hope This Helps You
Oct 17, 2013 | Boating
Spark Plug Gap
25th is the standard gap for nearly all engines
Jun 26, 2013 | 2007 Jeep Compass Limited
What is the gas/oil mix for an 80 hp johnson outboard motor
Even thought there are many expert tech's with sometimes more years of experience on this site than some you may find working in a repair shop, and of course many that simply give you their guess as the correct answer. I would recommend calling a Johnson Outboard Dealer or an outboard repair shop.
Jun 12, 2013 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
135 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
