Question about Cell Phones
AIR PIECE IS NOT WORKING - Cell Phones
    President:
  • 1,561 Answers
If the earpiece of your phone is not working, it means the earpiece of your phone is bad and will need to be replaced.
All you need to do is to change the earpiece of your phone and you will see that you can hear what people are saying while making or receiving calls.
Change the earpiece as advice and you see your problem with the earpiece is solved.
Take care.
Posted on May 06, 2010
My Purespa's bubbles wont work. The air pump keeps blasting the air and dislodging this one balloon clog piece. What can I do to make it stop dislodging this piece?
Is it plugged in "All" the way?
Possibly whatever "Retaining" lock grooves that kept it in originally, was smoothed out with the removal of it? Maybe a new piece will correct this?
Maybe contact Intex:
1-800-234-6839
OR VISIT WEBSITE: WWW.INTEXSTORE.COM.
Owners Manual attached
http://www.pool-j.com/pdf/574616.pdf
Intex PureSpa Owners Manual.pdf
Mar 10, 2015 | Intex Pool & Spa
Pump stopped working during the final rinse at end of descaling process. Note: we live in Vancouver, BC. The water here is naturally soft.
air compressor to the white piece above water reservoir and blow out the upper piece that pierces the coffee...chances are extra water got into the tubing where air needs to go
Apr 15, 2011 | Saeco Incanto Classic Espresso Machine
I have a Oasis Whirlpool tub that is not working. Model 1483.6P WHT. The push button to activate the whirlpool action remains depressed and I'm unable to get the system to turn on. Do I need to replace...
if you can get the button bezel to come up. try and get the center piece out by prying up the outside trim piece first then get the center piece out. Look down inside the button and see if the rubber boot is damaged. You probably need a new air button. you can clean up the inside of the air button with some fine emery cloth to remove any calcium deposits that can make an air button sticky.
Dec 22, 2010 | Home
How to repair water damage nokia2626
You must open the phone completely, disconnecting every wire/ board & dry out piece by piece (do NOT dry using hot air.. use warm/ cool air. Blow dry by fan..hand..air pump etc. This should work I am sure but it all depends on the damage condition of your cell.
Mar 02, 2010 | Nokia 2626 Mobile Phone
I have an Eagle 5000 air purifier. Stopped working
Just went thru this Tues. Get the top of screen in place and then push the plastic in on safety switch. I was having it push down and then slide screen in. That plastic piece is split like when you push it in, it hits 2 different heights. Instead of pushing it down get top in and push the plastic in, easy. Turned on then. Already had the switch on so it fired up soon as I pushed it in.
Jan 15, 2010 | Eagle Advantage Alpine Air Purifiers Eagle...
MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Jul 24, 2009 | Danby 7,000 BTU Portable Air Conditioner -...
Button on American Standard Whirlpool tub is stuck down, do I need to remove the entire piece to fix it?
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
Jul 11, 2009 | Home
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Air hammer tips
Always keep in mind that air hammers are extremely powerful tools. Thus, particular safety precautions should be taken when using them. Be certain to wear safety equipment such as safety glasses and earplugs. Also, when changing the air hammer's bits, always be sure to unplug the air hammer first. Finally when using an air hammer, always be aware of the position of the tool and work piece. The tremendous force that the air hammer exerts can cause the tool or work piece to jump powerfully. This movement could easily cause injury to the operator.
Aug 27, 2008 | Ingersoll Rand Air Hammer 2 9/32" Stroke,...
Cell Phones Logo
149 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
