Question about KitchenAid KHMS147 Microwave Oven
How do I replace the handle on my kitchaid microwave
  • KitchenAid Master
  • 9,085 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, you have to remove one screw, then rotate or lift the handle.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on May 06, 2010
How to replace handle
This is a difficult thing to explain in the text forum to change. Go to Youtube or RepairClinic to see videos to make this easier for you. Whirlpool microwave door handle replacement Door Handle Replacement part WB15X10249 GE Microwave Repair
I hope this helps
Aug 01, 2014 | Frigidaire FFMV162LW Microwave Oven
How to replace a door handle on a kitchaide microwave
Hello, Thank You for using FixYa. I will be helping you today.Its not easy and most people who try it for the first time break the door and need to buy a whole door.You need to use a putty knife and slide it into the door edge on the inside part of the door and pop the clips all the way around to seperate the door in two then you can change the handle.
Thank You and please rate my answer if it was helpful..
Jun 24, 2011 | KitchenAid Microwave Ovens
Where is the fuse located on a kitchaid microwave khms155l
It is located behind the key panel. UNPLUG THE UNIT FIRST.
Remove top grill (2 sinked screws on top)
Now remove the single screw on top of the key panel. Barefully slide out the keypad up and out. The smart people of kitchenaid put the dang fuse jammed between the fan housing and the right wall. Remove the entire bottom plate that holds the lights and such... I think 8 screws. Now remove 2 screws that hold down the fan housing. Now you going to have to use a screw driver and some wiggling to move the plastic housing out of the way enough to pop and slide out the fuse and replace. To test you can use a continuity tester and place it between the fuse. There is nothing visible on this fuse (250Volt 20A fuse Fast Acting I think) e.g. you can't see that the fuse is broken or not. Make sure no wires are pinched while putting it all back.
Dec 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Replace microwave door
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 On exploded view diagram 4, look at reference part number 4. That is the choke cover. It's held in place with hidden tabs. I've attached a diagram from a Sharp model that will be somewhat similar. Once the choke cover's off, the hardware should be visible. The diagrams do not show the hinged at all. That may mean they're welded to the chassis of the oven. Write back if this does not clear it up.
Mar 12, 2007 | KitchenAid KCMS145J Microwave Oven
KitchenAid KHMS147 Microwave Oven Logo
125 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
